Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 The rings were easy enough, once I figured the oil control ring assembly. They were all in spec, except the oil control which the gap was too large. I expect the design is different to original. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 The trick it to put the zig zag ring in the groove first. Then the lower ring and upper ring. Gaps opposite the pin. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 The ring pliers was useful. Clever thing. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Piston assembled, I need to check the gap positioning. The chrome ring had no taper, but the black ring did. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Chrome (top) and black (mid) rings: Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Then it was the bearings, I had to swap one over to get clearance on the with shell pinch test. But there were all within spec, just. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 4 pistons, ready to go. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Lots of super sticky oil, followed by torquing, all bar number five. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 8 hours ago, Landrover17H said: Ah, you're looking at this... No. This: Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Fitting the pistons was easy. The ring compressor worked a treat. Lots of lube, and most things fit. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 The Tee seals were a disaster. I did this ages ago, using a steel drinks can. All cans now are alloy. It didn't work. Â Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 I found smoke m some old seals, unused, and fitted those. That worked, but will they seal? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 After the pistons were done, I stuck the cam in. Lots of the black paste. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 I need a thicker thrust washer, even the new one is too thin. It's only 0.01 out, so I can live with it. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Tappet slides next. I changed two of the sliders, on account of the two rotten followers, and all the followers. All locked with new screws. Â Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 Here's a question: This is a reconditioned engine. Can I stamp it with a new number? Say, the date? Or the military registration? 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 The timing chain is next, but I can't go too far with it, as the instructions from Roland at ACR are quite specific, and need the head to be fitted. Â Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 I mean, it looks right, but I'm not locking anything until I've the head on. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 All I got done on the head tonight was a thorough clean. I've also noticed a lot of junk in the water galleries, I'm tempted to put the power washer nozzle in there once the engine is assembled. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 I think I'll change the valve seals, there's a set in the gasket pack. What do I need to clean the spark plug threads, is a quick brush with the Dremel enough? But once that's done I can fit the head. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 19, 2020 Share Posted March 19, 2020 Cut a slot in the thread of an old plug and run it down them. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 19, 2020 Author Share Posted March 19, 2020 22 minutes ago, Bowie69 said: Cut a slot in the thread of an old plug and run it down them. Â Good idea! I suppose I've one, I must have one. Somewhere. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 19, 2020 Share Posted March 19, 2020 For the tee seals, you need to bolt or clamp down a wedge block to guide them in without cutting. The manual shows them. They are easy to make yourself. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 20, 2020 Author Share Posted March 20, 2020 As I say, the shim steel works, but I could find any steel. Â Regardless, they're in now, and undamaged. The 110 manual didn't cover the wedges, I'll look up the series ROM to see what you mean. Â I'm going to look again at the cam, see exactly what meets with the aim of getting more clearance at the thrust point. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 20, 2020 Author Share Posted March 20, 2020 Or, should I say, less clearance! Quote Link to comment Share on other sites More sharing options...
