2.5 petrol rebuild and conversion to EFI thread?
Gazzar
Fabulous !  I want to ‘like’ but the forum isn’t telling me I’ve done too many 🤷‍♂️. That motor is going to look right at home in the lightweight 😊
I like the heat shrink ... what’s the thinking behind it?
Im thinking of changing the dip stick on my 80 to that style, the 200 Defender has that short freestanding one, and if I can have it twisted to the front it should hopefully clear my exhaust.
11 minutes ago, landroversforever said:
Apologies if you’ve already covered it but what did you do to prep? And what paint?
What's prep?
I cleaned it with brake cleaner, sprayed the exposed steel with ZG90, and whacked a load of U-POL etch primer on it.
Then spat paint on it with the cheap gravity feed gun that you find in a cheap set of cheap tools from Lidl.
The paint is recon MOD green from Paintman. Synthetic enamel, it's quite nice.
  • Like 1
On 3/5/2020 at 4:54 PM, FridgeFreezer said:
Thanks for these👍🏻 Just bought some bearings for some magnesium motorcycle wheels I have, that I’d been struggling to find 😊
9 hours ago, FridgeFreezer said:
Am I missing something or is there paint inside the head ports here? I would have thought those would be masked off to avoid filling the insides with paint? :huh:
I did think about that.
Exhaust will burn the paint away, so no problem. No cat to clog.
Intake has a smear of grease, so that will wipe away.
The lightweight(air portable) coil bracket has arrived:
This fits on the rocker cover on the 1/2 tonne air portable, so is like to use the same on the 17H.
Nige is aghast at mounting the Ford coil pack on the rocker, but I think if I put a heat shield on top it will be fine, a block of that plastic, or an aluminium sheet should be fine.
This is the "plan":
Mount a modified coil pack holder on the standard coil holder:IMG_20200709_124549.thumb.jpg.756e929270b0a36d0206af6d58c5927e.jpg
And trap a small, but lethal, heat shield between them, to protect the underside of the coil pack.
It's a heavy assembly.
Same as spec for the 2.5, maybe one heat range colder as you are updating things, but probably fine with regular ones.
Coils will be fine on the rocker, a very common thing to do where the coils were firing twice as often, as you know. LS engine have them on the rocker, and they tend to be quite reliable.....
Remember an engine is only the water temperature, apart from the exhaust manifold and a bit of the head next to it.
My V8 coil packs are mounted to the side of the plenum....right above the rocker cover(!).
I would check bonnet clearance, if you can? The coil packs are probably a little taller than a traditional coil on its side.
  • Like 1
I think I've the easy sensors sorted.
Honestly, I only intended to potter this evening.
But, I got carried away.
Manifold air temperature sensor location selection.
I had an idea to hide this under the swan neck, but clearance works have been an issue.
Then the coolant sensor.
I got lucky here.
The gauges I fitted in the LWB came with adapters. One of these threaded into the thermostat.
It wasn't so good on the sensor side, but I had a tap.
It will work, some judicious copper washers and it be fine.
  • Like 2
Oh. And the fan.
The pulley and the fan.  The pulley mount holes are series, the water pump is metric, M8.
I had to drill them out.
Still, it's on. Should it be yellow?
  • Like 1
The thermostat on the 17H is taller than the series. The shorter bolts arrived after I painted the engine.
I know, I know, I could have tapped the original ones more and cut them short.
But I bought new.
