mej999 Posted January 15, 2020 Share Posted January 15, 2020 Hi, New to this forum. I have just fitted a Mega jolt system to my LR Rover V8 with 4.6 bottom end and 3.9 14 CUX top end. I have searched the internet and this forum for hours looking for a good Ign Map. I can find lots for 3.9, 3.5 etc but nothing for a 4.6. Everything I read says that a 4.6 should not have as much advance as a 3.9 etc. Does anybody have a good map as a starter for 10? Thanks, Michael Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 15, 2020 Share Posted January 15, 2020 I have a couple of .msq files from my 4.6's you could extract the ignition maps from, would have to dig the laptop out of the garage though. Quote Link to comment Share on other sites More sharing options...
mej999 Posted January 16, 2020 Author Share Posted January 16, 2020 Hi Fridge, That would be fantastic. Look forward to hearing from you. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 16, 2020 Share Posted January 16, 2020 We (I!) would also like to see your comp safari racer!! Regards Steve (a fellow comp safari racer!) Quote Link to comment Share on other sites More sharing options...
mej999 Posted January 16, 2020 Author Share Posted January 16, 2020 Hi Steve, Tried loading a picture, but have not managed to work out how to do it yet. Will try again tomorrow. M Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 16, 2020 Share Posted January 16, 2020 Right, here's my (Megasquirt) MSQ's plus a screenshot just in case... The 109 (4.6 V8, piper stump-puller cam): http://fuddymuckers.co.uk/files/ms/109_current.msq The 127 (Stock 4.6 V8, GEMS type): http://fuddymuckers.co.uk/files/ms/127_current.msq You should note that although I can solder 'em together I'm a muppet at tuning, these have been set up by more knowledgeable types and I've made minor tweaks where I've felt the need - so don't take these as a masterpiece of performance tuning - there's likely a lot that could be improved! Also bear in mind your timing marks have to be right in the first place Quote Link to comment Share on other sites More sharing options...
mej999 Posted January 17, 2020 Author Share Posted January 17, 2020 Hi Fridge, Thanks very much for the maps. Is the left axis in KPA? Which one would you recomend I start with? 3.9 14 cux top end and used for racing? Are the map colours significant? Just wondering what they mean if anything? Regards, Michael Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 17, 2020 Share Posted January 17, 2020 Screenshots from TunerStudio so yes the left axis is kPa. Colours are just for looking at Honestly I don't think it matters which you use, probably the 127 one as it has a stock cam but would you be worrying this much about swapping a distributor across from one engine to another? Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted January 17, 2020 Share Posted January 17, 2020 13 hours ago, mej999 said: Hi Steve, Tried loading a picture, but have not managed to work out how to do it yet. Will try again tomorrow. M When you hit reply on a post it'll bring up a box (like I've attached) and you hit the choose file below where you're typing, it'll be high lighted in blue. Then once it's uploaded, you can press the '+' to add it into the text, like here: And then you can carry on typing! Hope this helps! Steve Quote Link to comment Share on other sites More sharing options...
mej999 Posted January 27, 2020 Author Share Posted January 27, 2020 Hi Steve, Please see picture attached. M 1 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted February 10, 2020 Share Posted February 10, 2020 (edited) Very nice! I've always wanted to watch or have a go at some of the rallies up north, The scottish hill borders rally in particular, but being they're in Scotland and I'm in Kent, it's all a bit far away!! Steve Edited February 10, 2020 by steve200TDi Quote Link to comment Share on other sites More sharing options...
