Green200tdi Posted January 18, 2020 Share Posted January 18, 2020 From cold 🥶 fires up a treat once been running few minutes turn it off re start, earth strap from battery to out rigger, earth strap from chassis to engine, new battery 750amp new starter motor, 200 tdi Quote Link to comment Share on other sites More sharing options...
blowmeover Posted January 18, 2020 Share Posted January 18, 2020 Sounds like your battery isnt holding charge, or you fitted the wrong starter motor, do you have a multimeter? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 18, 2020 Share Posted January 18, 2020 I had a 200 that did similar, what you don't want to hear is it eventually snapped a cam. I suspect the cam bearings had turned thus cutting the oil to the cam. The other thing that backed this up was a flickering oil pressure light at tickover when warm. Mike Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 18, 2020 Share Posted January 18, 2020 Where did the mew starter come from, is it a Bosch/ Velao or "a.n. other"? Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 19, 2020 Author Share Posted January 19, 2020 3rd starter the other 2 were different seller got money back as were recons, my original starter turns it over fires it up straight away but kicks out to soon, but as cold set in this year and original battery died got harder, then was jump starting every time wanted to go anywhere, photo of new starter see part number just a thought wonder if new head gasket giving me better compression might have something to do with it 🤔 Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2020 Share Posted January 19, 2020 23 hours ago, Green200tdi said: From cold 🥶 fires up a treat once been running few minutes turn it off re start, earth strap from battery to out rigger, earth strap from chassis to engine, new battery 750amp new starter motor, 200 tdi Change the battery earth from the negative terminal to one of the main gearbox to transfer box bolts, that's where my battery earth connects, as well as another earth from engine below alternator to chassis part of left engine mounting, clean any paint & dirt off to get a clean sound connection. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 19, 2020 Author Share Posted January 19, 2020 Cheers Ralph 👍 will give it a go 1 Quote Link to comment Share on other sites More sharing options...
Maverik Posted January 19, 2020 Share Posted January 19, 2020 I've not had great experiences with non branded starters, you can get enough bits on ebay you can rebuild genuine ones easily enough. After installing a non branded one and running it and it failing going back to a valeo unit i then realised how poor the non brand was from the beginning, it never turned the engine over as strongly as the valeo unit. Quote Link to comment Share on other sites More sharing options...
blowmeover Posted January 19, 2020 Share Posted January 19, 2020 What power rating is the starter? There are two different kinds. Quote Link to comment Share on other sites More sharing options...
western Posted January 19, 2020 Share Posted January 19, 2020 That new starter is the same part number that I fitted to my 200tdi a few months ago, it spin the engine over very well. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 20, 2020 Author Share Posted January 20, 2020 This is this morning without glow plugs turns over very slow but soon as I get a chance I’ll upgrade the Earth on the 110 see if that helps, two vids one from cold ( bloody freezing actually)😂 and one warm starting DD489557-0DAE-410C-8EFE-10CBC9EBFA4B.MOV Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 20, 2020 Author Share Posted January 20, 2020 Won’t let me upload the main vid but take another shorter one soon Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 20, 2020 Share Posted January 20, 2020 You can prove the problem by running jumpleads direct from battery to earth point to cut out any dodgy earths. 1 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted January 21, 2020 Author Share Posted January 21, 2020 New earth cable and connector 2 meters so enough to go to bell housing 1 Quote Link to comment Share on other sites More sharing options...
blowmeover Posted January 21, 2020 Share Posted January 21, 2020 You will need one to the chassis as well, I have both on mine, I usually buy mine already made up, crimping big terminals like that never worked out for me! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 21, 2020 Share Posted January 21, 2020 You just need a big crimper or a chum with one 😉 Mo Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 21, 2020 Share Posted January 21, 2020 I now have a terminal crimper but prior to that I used to use an engineer's v block and punch always worked very well regards Stephen Quote Link to comment Share on other sites More sharing options...
western Posted January 21, 2020 Share Posted January 21, 2020 My battery to gearbox earth cable is the Factory fitted item, the engine to chassis earth I bought ready made from Halfords, it was much thicker than the factory original. Quote Link to comment Share on other sites More sharing options...
