series3 steve Posted January 18, 2020 Share Posted January 18, 2020 Good evening,everyone, At the moment I am nearly 90% finished of a restoration of a series 3 swb with a 200di engine fitted ,and I bought a prc6913 glowplug relay, and has a new autosparks wiring harness for a SERIES/ 200dti engine I have looked at many comments about relay wiring but most use the wiring from a 200tdi but mine does not corrispond with those wiring colours, my wiring going to where the old resistor/glow plugs is A heavy brown /red cable white /blue small brown/red Black for earth. I know I will require more wires but to what and to which terminals on the six pin relay ,any advice will be welcome Thanks Steve Quote Link to comment Share on other sites More sharing options...
Arjan Posted January 20, 2020 Share Posted January 20, 2020 Can't help you with this as we use custom build looms & omitted the relay you mentioned. We pre-glow manually However, looking at the relay : Think you can work it out with a simple test set-up. Bon Courage ! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 20, 2020 Share Posted January 20, 2020 Never needed it. Mine starts without. But, if you're Arctic based, then you'll need it. Quote Link to comment Share on other sites More sharing options...
