TAZA Posted January 20, 2020 Share Posted January 20, 2020 Taza Member Joined: Jan 11, 2009 Posts: 54 Likes Received: 0 2004 Facelift (Manual) Engine wont turn over,everything seems dead Put key in ignition and wont start not cranking, all that happens is i get 6 like audible alarm pings My key fob has not worked for years i just open manually, noticed this time all the other doors don't unlock. Alarm LED on dash not lit or flashing Thought it might of been battery so charged it up and still the same. Red LED flashing on Navigation System goes of when turn key Also flashing symbol in the digital mileage display looks like a B Is there any fuses for ECU,I have nanocam so if there is anything that I could check (limited use on this)T Things that don't work Windows Indicators Seats Sun Roofs Central Locking Things that work Horn Blower Wipers Lights lighter Any help appreciated Quote Link to comment Share on other sites More sharing options...
bear Posted January 21, 2020 Share Posted January 21, 2020 Do a search on web for the flashing B or visit the d2boysclub forum. Loads of info there. Griff Quote Link to comment Share on other sites More sharing options...
TAZA Posted January 21, 2020 Author Share Posted January 21, 2020 Guys Just an update on the fault, before I started going down removing the BCU unit I thought I would take a chance and put a Electric Heater inside the car, Disconnected Battery Unplugged all the connections on BCU Put electric heater in the footwell pointing up at the unit Left for couple of hours Fitted all plugs back Connected Battery Back Up Bingo it started Quote Link to comment Share on other sites More sharing options...
TAZA Posted January 23, 2020 Author Share Posted January 23, 2020 Its back put heater back on and fault cleared, it wasn't even raining ? any help appreciated Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 23, 2020 Share Posted January 23, 2020 Just skimming this, if there's a bad or cracked solder joint on a PCB, heating it up can re-make the connection temporarily. If you can open the unit & check the solder joints it might show something - although the cracks can be microscopic so sometimes just touching the soldering iron on each joint to re-flow the solder and hoping is all you can do. Only if you're competent at soldering though, otherwise you risk making things far far worse. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted January 25, 2020 Share Posted January 25, 2020 On 1/23/2020 at 10:15 AM, TAZA said: Its back put heater back on and fault cleared, it wasn't even raining ? any help appreciated Keep the heated on it 🤣 Quote Link to comment Share on other sites More sharing options...
Jonfo Posted May 1, 2021 Share Posted May 1, 2021 Hi , jumping in on this exactly similar occurred today . It rained a little bit, been really dry . Disco 2 2001 v8 . Tape over the sunroof for years . I leave it unlocked . Went to use it ( had last done so 20 hours previously) . Cluster lights on , doors locked , only worked manually . Front right indicator light and repeater on . Radio and climate on . It started even if I “immobilised “ it . I disconnect battery to have that hope it would fix everything and boost power and improve mileage at the same time , naturally it won’t start at all now as the immobiliser now works , and the remote doesn’t . I will try the heater out of interest , but the explanation about the Pcb improving momentarily seems plausible ( given the heat in the car could be significant) . or should I just get another BCU? I have just got a series 3 so no doubt I will be back , I have no clue about this really . I like ‘em though . Quote Link to comment Share on other sites More sharing options...
OscarHC Posted August 6, 2021 Share Posted August 6, 2021 How did you go sorting this issue? I’m having the same problem with my D2 tonight, Parker it and was doing other things then went to start it and this is happening. Have pulled bcu and fuse box with no prevail. Quote Link to comment Share on other sites More sharing options...
