A frame build
Stellaghost
 Share
So with a possible house move at some point in the next year I've  decided to make an adjustable height A frame so I  don't need assistance from someone with a telehandler to move my milling machine, lathe etc also will be handy when I lift body off for portal axle project.
Progress so far
Mag drill helping with holes
Edited by Stellaghost
Addition
  • Like 1
1 hour ago, steve b said:
What sort of capacity are you aiming for?
cheers
Steve b
Looking to lift my lathe and milling machine when we find a house that gives me more work space and a couple of acres for the dogs to play milling machine is 750kg and lathe is about 1500kg so about 2000kg max I also plan to use it to lift body off lightweight at some point regards Stephen
More progress and an incident20200211_170520.thumb.jpg.e2c9da58ac1ec400ad6697c1be8401c0.jpg20200211_170500.thumb.jpg.95c0db7ed2b62a48320e1e8e5006e392.jpg
On a side note sometimes you need assistance which I haven't got so if it can fall over it will I was lucky wrecked a grinder battery but grinder ok I jumped out of the way 20200211_140850.thumb.jpg.1b31aaffe5a6641273d10ea1345d0fda.jpg
Regards Stephen
Change picture
 Share
