Rear Tub Rivets
uninformed
Solid are 3/16 diameter of various lengths.
Crossmembers seem to be something bigger - may be 1/4 in but as that's 6.35mm a 6.5mm drill shuld remove them.  I use 1/4 in bolts.
Blind (pop) rivets are 3/16 or 4.8mm x generally 10mm - closed type.  Some are longer - I use 16mm which seems to do the job.
https://www.bits4landys.co.uk/rivets/series2-s3.htm
Stainless washers may cause galvanic corrosion problems in contact with the alloy - ie get it wrong and it'll dismantle itself in a few years.
