L19MUD Posted January 31, 2020 Share Posted January 31, 2020 Has anyone got any suggestions for a supplier of something decent? I have seen what VWP have to offer but I would rather I didn't have to sell a kidney to fund a bit of plastic! I have 7 fused circuits, with 5 relays to accomodate and would like room for some expansion so 10 fused circuits and 6 relays would probably be about right. What have others used? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 31, 2020 Share Posted January 31, 2020 I'm using VWP's modular fuse/relay box thing. Mini blades and relays lets you get quite a lot in a small space - 26 fuses (which can be bussed), 10 relays, plus flasher unit / full size relay in their 4-slot housing. 3 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 31, 2020 Share Posted January 31, 2020 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F401772423890 I’ve got one of these to use for the head light wiring upgrade , and there’s also an 18 relay one for not a lot I’ll see if I can find a link if your interested. 1 Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted February 4, 2020 Share Posted February 4, 2020 Could you not use an second hand Range Rover P38 fuse box? Or am I being too green mean? Quote Link to comment Share on other sites More sharing options...
L19MUD Posted February 4, 2020 Author Share Posted February 4, 2020 2 hours ago, Simon_CSK said: Could you not use an second hand Range Rover P38 fuse box? Or am I being too green mean? Happy to use anything that will do the job! Thinking about it I have a Volvo 850 in the yard I'm stripping for spares...I wonder what the fuse box is like in that Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted February 4, 2020 Share Posted February 4, 2020 I do know the P38 has a series of plugs that go in the base and can be wired through those. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted February 5, 2020 Author Share Posted February 5, 2020 9 hours ago, Simon_CSK said: I do know the P38 has a series of plugs that go in the base and can be wired through those. Yes looked at the P38 one and the design leads itself to being used for other things. The Volvo one in the yard has specific plugs which won't work as well. Will have a trawl of ebay/the local scrappy for one Quote Link to comment Share on other sites More sharing options...
Escape Posted February 5, 2020 Share Posted February 5, 2020 The P38 fuse box is very handy in that it takes standard spade connectors. But the internal wiring is not always straightforward, so it will take some time to figure out how it can be put to other use. Filip Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted February 5, 2020 Share Posted February 5, 2020 58 minutes ago, L19MUD said: Yes looked at the P38 one and the design leads itself to being used for other things. The Volvo one in the yard has specific plugs which won't work as well. Will have a trawl of ebay/the local scrappy for one I may have one in my shed lol Quote Link to comment Share on other sites More sharing options...
L19MUD Posted February 5, 2020 Author Share Posted February 5, 2020 2 hours ago, Simon_CSK said: I may have one in my shed lol Happy to supply beer tokens for it ! Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted February 5, 2020 Share Posted February 5, 2020 7 hours ago, L19MUD said: Happy to supply beer tokens for it ! Have sent you a pm 1 Quote Link to comment Share on other sites More sharing options...
tiny1664 Posted February 6, 2020 Share Posted February 6, 2020 I bought one of these https://www.ebay.co.uk/itm/12V-32V-12-Way-Blade-Fuse-Box-Bus-Bar-Car-Boat-W-Cover-Marine-FuseBox-Holder/264325889467?_trkparms=aid%3D888008%26algo%3DDISC.CARDS%26ao%3D1%26asc%3D20131227121020%26meid%3D1b4caf2107d543f5bf73c69a53544993%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D401772423890%26itm%3D264325889467%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100009.m1982 and plan to do something like this 1 Quote Link to comment Share on other sites More sharing options...
L19MUD Posted February 10, 2020 Author Share Posted February 10, 2020 On 2/5/2020 at 9:56 AM, Escape said: The P38 fuse box is very handy in that it takes standard spade connectors. But the internal wiring is not always straightforward, so it will take some time to figure out how it can be put to other use. Filip I now have one kindly supplied by Simon. Do you have any wiring diagrams that will help me get started? 1 Quote Link to comment Share on other sites More sharing options...
Escape Posted February 11, 2020 Share Posted February 11, 2020 You need to know what car it came from, the partnr will proably tell you. There are some differences between petrol and diesel and some changes made over the years (1999 being a pivotal year). I haven't seen any wiring diagrams specifically for the fusebox. Rave does list all the fuses, that will get you started. For the relays, your best bet will be to look up the standard wiring and see what you can do from there... Truth be told, it's not something I'd like to tackle. But 5 or 6 relays should be doable, things like heated windscreen (2 of ), EAS compressor, starter motor and front fogs are straightforward. Good luck and happy to try and help should you get stuck! Filip Quote Link to comment Share on other sites More sharing options...
L19MUD Posted February 11, 2020 Author Share Posted February 11, 2020 Yes fair point, i will find the part number later and stick it into Microcat then print off the relevant Rave diagrams. My thoughts too, it can't be that bad to work out with the continuity function on the multimeter. I will share progress and results on here in case anyone else can use what I find. My initial plan is to test continuity from the live post that takes power direct from the battery to see what side of the fuses power up and then fit fuses one at a time to see the power to the relays. Seems a better use of time sat in the house playing with the multimeter than watching dross on TV! Watch this space for me getting stuck and confused! Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted February 11, 2020 Share Posted February 11, 2020 Sam It is definately a Petrol and will not be from any vehicle newer than 2001 as I have only broken petrols and of those 3 were Gems and two were Thor 1 Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted February 20, 2020 Share Posted February 20, 2020 On 2/6/2020 at 1:46 AM, tiny1664 said: I bought one of these https://www.ebay.co.uk/itm/12V-32V-12-Way-Blade-Fuse-Box-Bus-Bar-Car-Boat-W-Cover-Marine-FuseBox-Holder/264325889467?_trkparms=aid%3D888008%26algo%3DDISC.CARDS%26ao%3D1%26asc%3D20131227121020%26meid%3D1b4caf2107d543f5bf73c69a53544993%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D401772423890%26itm%3D264325889467%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100009.m1982 and plan to do something like this I really like this arrangement, and I wish that my wiring will look so good, but what is the module on the right hand end of the fuse box, the item with the yellow clip? I've been trying to work out the wiring. There's going to be supply and ground for each relay coil, and then there's going to be switched power in and out of each relay. I assume that switched +12V comes to a bus-bar at bottom left which feeds the fuses, but from there, which wires are which? I hope some electroadult can help me😕. Mike Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 20, 2020 Share Posted February 20, 2020 The module is a bussed fuse holder with ground connections: https://www.bluesea.com/products/5026/ST_Blade_Fuse_Block_-_12_Circuits_with_Negative_Bus_and_Cover They're pretty handy, I used one in our camper. 1 Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted February 21, 2020 Share Posted February 21, 2020 Many thanks for the details and the link. They're expensive, but allow a really tidy wiring arrangement. I think you've just sold a couple of these, a 12-way and probably a 6-way. Mike Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2020 Share Posted February 21, 2020 9 hours ago, Troll Hunter said: Many thanks for the details and the link. They're expensive, but allow a really tidy wiring arrangement. I think you've just sold a couple of these, a 12-way and probably a 6-way. There's cheaper places to buy them and there's cheaper copies/versions out there too depending what you're doing. Anything with "sea" or "marine" on the box adds ~100% markup although BlueSea are decent quality. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted February 21, 2020 Share Posted February 21, 2020 ^^^ Agreed. Searching Amazon.ca I found this: https://www.amazon.ca/dp/B07F3CX7B3/ref=pe_3034960_233709270_TE_item. Considerably cheaper than Blue Sea, and I just hope it's not the local equivalent of a Britpart quality component. I'll report if there are any deficiencies. Mike Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 21, 2020 Share Posted February 21, 2020 The cheapy one has fuse-blown warning LED's in it too, a nice touch! Quote Link to comment Share on other sites More sharing options...
SteveG Posted February 23, 2020 Share Posted February 23, 2020 Not cheap, but a neat solution... https://store.switchpros.com/ Quote Link to comment Share on other sites More sharing options...
