Santino1983 Posted February 1, 2020 Share Posted February 1, 2020 Hello All Brief Introduction - I was stationed in the UK from 2015-2019 and while there picked up my dream car. A USA importable defender 110. I love these cars as they don’t punish you (too badly) when working on them if you make a mistake. Needless to say ownerships has been everything I wanted and more. Now the bad part: Getting things fixed on these things is incredibly expensive unless you do it yourself. I know I know Captain Obvious right? So the Problem I am having is ATF is seeping down the front of my transfer case - its not the LT230 oil - its red and it tastes different. The transmission is a rebuilt Ashcroft with less than a 1000km on it so I am pretty sure the gearing and seals on the transmission are ok as for the T-Box I cant speak to that. I have combed the tech archive and haven’t found anything about this problem - then again I may not know exactly what I am looking for either. Any help you all can give will be much appreciated Thanks Again Santino Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2020 Share Posted February 1, 2020 Oil seal on rear of main gearbox, to replace it is a transfer box off job, main gearbox is most likely a LT77 which use ATF [Automatic Transmission Fluid] Don't use EP90 oil in main gearbox, it's to thick for the built in oil pump. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 2, 2020 Share Posted February 2, 2020 Likely leaking as western says. My Ashcroft R380 started leaking at a year old. Apparently years later they found out they used a batch of substandard main shaft rear collars where the oil seal runs on. I've lived with it for 8 years as it's not worth the effort to fix. The oil level goes down less than 100ml between 2 yearly services Quote Link to comment Share on other sites More sharing options...
