Paul Humphreys Posted January 4, 2007 Share Posted January 4, 2007 How can I tell if its any good when it`s not on a LR? I have been offered a 1.6 for my 110 and need to make sure its ok before I pay for it. Paul Quote Link to comment Share on other sites More sharing options...
white90 Posted January 4, 2007 Share Posted January 4, 2007 drive it listen for odd noises in high/low and in diff lock(if possible) if poss remove the PTO cover and bearing carrier then remove the input gear and have a look at the gear itself, with a torch you can look at the gears in the box, finally drain the oil check the drain plug for broken bits(small amount of swarf on drain plug is pretty normal. disgusting oil or burnt oil I'd leave it as it hasn't been looked after. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted January 4, 2007 Author Share Posted January 4, 2007 drive it listen for odd noises in high/low and in diff lock(if possible)if poss remove the PTO cover and bearing carrier then remove the input gear and have a look at the gear itself, with a torch you can look at the gears in the box, finally drain the oil check the drain plug for broken bits(small amount of swarf on drain plug is pretty normal. disgusting oil or burnt oil I'd leave it as it hasn't been looked after. Thanks for that, but as per my first post its not fitted to a land rover right now. Price is ok at £50 and I am told it its a good one. But do not want to fit it and find out its no good. Paul Quote Link to comment Share on other sites More sharing options...
white90 Posted January 4, 2007 Share Posted January 4, 2007 I'll read twice next time. oil and gear checks still worthwhile Quote Link to comment Share on other sites More sharing options...
Andy Posted January 4, 2007 Share Posted January 4, 2007 turn it over by hand & feel for roughness or tightness? waggle the flanges/any gears you can reach to check for bearing play check both ratios & with/without difflock - both easy to change on a tbox standing alone Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 5, 2007 Share Posted January 5, 2007 Lock up the center diff and rotate the flanges in opposite directions. Too much play in the centre diff and the box is quite tired. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted January 5, 2007 Author Share Posted January 5, 2007 Thanks for that. I think I will get it and give it a go. Then some bigger tyres!! Paul Quote Link to comment Share on other sites More sharing options...
