Fuses
It should be the supply to the TD5 ECU. So without it, it wont run. Unless someone has rewired it?
Also, the 4th fuse from the left should be 10A (reverse lamps) and the 2nd  from the right 15A (wiper delay). Judging by the type, both have already been replaced.
For reference, the full fuse layout for the late TD5:
Fuses TD5.pdf
Filip
Filip
Thanks it’s a spare then 😂
no ecu 200tdi in my 86 110
 Share
