Bowie69 Posted February 8, 2020 Share Posted February 8, 2020 No, it will keep working 2 Quote Link to comment Share on other sites More sharing options...
DC_ Posted February 8, 2020 Author Share Posted February 8, 2020 40 minutes ago, Bowie69 said: No, it will keep working Splendidness 😊 Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2020 Share Posted February 8, 2020 1 hour ago, DC_ said: Who ever did it before Ralph spliced the two together. It was a surprise. And I’m not sure where to plug them in individually. So if one bulb goes... they all go? Only if your unlucky & both bulbs pop at the same time, Left tail light & number plate light is Red with Black trace wire Right tail light is Red with Orange trace wire. If you put the trailer 7 core Brown to the Red with Orange that will be ok & 7 core Black to Red with Black, your sorted. Quote Link to comment Share on other sites More sharing options...
DC_ Posted February 9, 2020 Author Share Posted February 9, 2020 @Bowie69 spot on ! I changed the blue bullet connector to the salvaged longer one. Fitted much better. 😎 the fog lamps need changing to 12v as they are currently 24v. I can’t get them off. My hands are aching from trying. Also the front white tail light is seized..... any trick to get em off? Quote Link to comment Share on other sites More sharing options...
western Posted February 9, 2020 Share Posted February 9, 2020 Have a look as there may be a screw in the threaded part that a previous owner has put in as a anti theft device. don't know if you've had the vehicle fromits day of coming out of service. if nothing found get some PlusGas releasing fluid, its much better than trying WD40 which is a water dispersant. Quote Link to comment Share on other sites More sharing options...
DC_ Posted February 9, 2020 Author Share Posted February 9, 2020 24 minutes ago, western said: Have a look as there may be a screw in the threaded part that a previous owner has put in as a anti theft device. don't know if you've had the vehicle fromits day of coming out of service. if nothing found get some PlusGas releasing fluid, its much better than trying WD40 which is a water dispersant. Can’t see anything different about the screw on fixtures Ralph.... totally agree about plusgas,.....after all..... it took them 40 attempts to disperse water 😎🙌 The rear of the tail and fog lamps have three nuts on bolts.. they loosen up but don’t come off..... just another challenge Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2020 Share Posted February 10, 2020 Not 100% sure but I think the military light bases have threaded studs, so they may have let go in the bases, Quote Link to comment Share on other sites More sharing options...
