Reverse lights on in p, r 3 and 2 p38
Blobthebuilder
 Share
Hi peeps this is an odd 1 I had to have becm, ecu and keys sent away which ment car sat for 10 days and when refitted I'm getting reverse lights on and rear wipers on if wipers are on in gears p, r, 3 and 2 but not in d, n and 1 although when becm was first fitted they were on in every gear so could it be a switch fault or likely the becm
What do the lights next to the gearstick say? And the gear selected on the dash? The first is controlled by the gearbox witch, the latter through the BECM. This could give an indication as to were to look for the problem. As the BECM has been removed, I'd double check all the connections first.
Filip
The led beside the gears is corret but nothing on dash at all except high when it's put In high and low when put into low and select neutral just after the lights stop flashing on either high or low but it never displays p, r, n, d, 3, 2 or 1 on dash I've also checked all connections bud and all connected in and correct only difference with becm was 1 I took out had earth cable that screwed on top and onto were front outer seat bolt goes and replacement didn't
Edited by Blobthebuilder
 Share
