Mutley Posted February 8, 2020 Share Posted February 8, 2020 I am going to get NEW rear brake callipers for the 300Tdi Defender 90 and want to paint them so they don't just turn into chunks of rust over time! Question is do I split the callipers so I can paint the inside after masking off the pistons, this way making sure that it all gets a coat of paint even where the x2 parts fit/bolt together so rust does not have an edge to work in from? They will be degreased first then the idea is split mask of pistons, bleed valve and pipe fixing and bolt holes then give x2 coats of paint all over......Is this a good plan? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 8, 2020 Share Posted February 8, 2020 Personally I wouldn't bother splitting them, if you use an aerosol to paint them then the coverage will be very good and get into the corners. You will always have an 'edge' where the cylinder walls meet the outside bit of the casting, and the bleed nipple, and where the caliper mounts, so I wouldn't get too precious about it. If you use something like ZG-90 then that may help you resist the rust a little longer. I assume they are zinctec'd already? Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 8, 2020 Author Share Posted February 8, 2020 @Bowie69 I was going to use E-Tech Calliper paint? 13 minutes ago, Bowie69 said: zinctec'd already? And what is zinctec'd ready???...…..Hopefully the callipers will be AP Lockheed and was going to degrease then just use E-Tech spray paint (Green) or do they need some kind of primer first? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 8, 2020 Share Posted February 8, 2020 The yellow zinc passivated finish. i.e. they already have some protection from the elements if they are yellow. Paint will always help of course Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted February 8, 2020 Share Posted February 8, 2020 I split them to paint them. It was the most pointless thing I've done. I'd put the money and effort to paint new ones into a piggy bank for replacement OEM calipers in 10 years. Quote Link to comment Share on other sites More sharing options...
western Posted February 8, 2020 Share Posted February 8, 2020 I've been refurbishing my front caliper with new seals & stainless pistons, I wire brush them, cleaned in brake cleaner & refitted, I was going to spray them gold same as I used on my engine, but it's just to cold for a decent finish. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted February 10, 2020 Share Posted February 10, 2020 On 2/8/2020 at 7:56 PM, western said: I've been refurbishing my front caliper with new seals & stainless pistons, I wire brush them, cleaned in brake cleaner & refitted, I was going to spray them gold same as I used on my engine, but it's just to cold for a decent finish. Nice and warm in the house 😁 Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2020 Share Posted February 10, 2020 I didn't bother painting the calipers just gave them a good clean up with a wire brush in my mains drill, not long finished the rear ones, time to relaxing & warm up. Quote Link to comment Share on other sites More sharing options...
western Posted February 10, 2020 Share Posted February 10, 2020 5 hours ago, L19MUD said: Nice and warm in the house 😁 Don't want the house stinking of paint. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 10, 2020 Share Posted February 10, 2020 That's what we need - gun clean or brake cleaner aroma air fresheners ! 😂 Mo 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 10, 2020 Share Posted February 10, 2020 Gotta be better than 'Cinnamon spiced dewberry' or whatever rubbish 'they' seem to think smells good! 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 10, 2020 Share Posted February 10, 2020 They also do petrol, used 90 oil and electrical short aromas 😁 Mo Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 10, 2020 Author Share Posted February 10, 2020 Ah you lucky, lucky B******;s...….. What i'd give for the pleasant aroma of diesel and burnt EP90 oil with an aromatic hint of ATF!?!...…... But NO!!!...… I have the expensive Au de toilet HORSE PEE with the strong after tones of intense HORSE POO!!! Thanks to the wife and her four legged friend!?! Many a time I've had to sneak out to the shed just to snort a couple of lines of WD40 2 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 11, 2020 Share Posted February 11, 2020 Surely she should be letting you sleep in the house again by now ? 😉 Mo Quote Link to comment Share on other sites More sharing options...
lo-fi Posted February 14, 2020 Share Posted February 14, 2020 Don't call him Shirley I have a mate who loves the smell of EP90. He's wifeless, so various people have made him EP90 scented things over the years. Air fresheners, candles - even cologne! Quote Link to comment Share on other sites More sharing options...
Mutley Posted March 8, 2020 Author Share Posted March 8, 2020 Cleaned up new rear brake calipers for the 90 and gave them x4 coats of paint the y don't seem too bad having taken the masking tape off!?! again time will tell if it's a worthwhile exercise? But for now they smart. used this paint! Had good reviews. Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 8, 2020 Share Posted March 8, 2020 That's the same stuff I used on my fronts the other day. I figured it can only help protect the galvy a bit longer. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 9, 2020 Share Posted March 9, 2020 I cleaned one set up with wire brushes and painted them with smooth Hammerite, the second set I had media blasted and the guy sprayed them with red oxide, which I then painted with Hammerilte. Neither set have had any rust, flaking or discolouration. I rebuilt the callipers with Zeus stainless pistons, and they are lasting extraordinarily well - not a mark on the first set after well over a decade. 1 Quote Link to comment Share on other sites More sharing options...
