chazzb Posted February 20, 2020 Share Posted February 20, 2020 Hi Guys, I have a simple question that I cannot find the answer to anywhere.. I've just had the roof and side panels on my TDCI off and can't remember what spacers were used to set the gap between the tub and side panels. Can anyone suggest what spacers + a link if possible. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 21, 2020 Share Posted February 21, 2020 I’m not aware of a spacer? But there is a seal? Quote Link to comment Share on other sites More sharing options...
simonb Posted February 21, 2020 Share Posted February 21, 2020 Correct no spacers, just the seal. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted February 21, 2020 Share Posted February 21, 2020 (edited) 39 minutes ago, simonb said: Correct no spacers, just the seal. Incorrect, Pumas with factory bulkhead removal option have spacers above the capping. Should be 4x round spacers that bolt onto capping, the m8 bolts are long (50/60mm ish) and go all the way through the spacers and form studs. Two are positioned rear corner, two at front mounting point. Edited February 21, 2020 by oneandtwo Quote Link to comment Share on other sites More sharing options...
western Posted February 21, 2020 Share Posted February 21, 2020 Would these spacers be item 26 in the diagram here Part Number Description AZT500020 SLEEVE Quote Link to comment Share on other sites More sharing options...
