P38 Paul Posted February 20, 2020 Share Posted February 20, 2020 Time has come to replace the fuel pump again on the P38 , this will be the forth time I have done this job with the last one only lasting around 15000 miles , can anyone advise me on a brand that may last a bit longer than this aftermarket one that is currently fitted to the car , cheers . Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted February 20, 2020 Share Posted February 20, 2020 Paul If you are replacing them that often can I dare to suggest that you fit a genuine Land Rover one? Maybe a second hand one? 15000 miles is an incredibly short time for it to last. Quote Link to comment Share on other sites More sharing options...
Waffle Posted December 13, 2020 Share Posted December 13, 2020 That sounds bonkers. Bearmach run a 3 year warranty with their own brand so maybe that’s a way forward? have you checked the fuel lines to make sure the return line isn’t perished and letting air back into the pump? Not sure if that would make it run dry on occasion? Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted December 13, 2020 Author Share Posted December 13, 2020 2 hours ago, Waffle said: That sounds bonkers. Bearmach run a 3 year warranty with their own brand so maybe that’s a way forward? have you checked the fuel lines to make sure the return line isn’t perished and letting air back into the pump? Not sure if that would make it run dry on occasion? Hi , that was a Bearmach pump that I had fitted but it had run out of warranty as it took me around three & a half years to cover the 15000 miles before the pump started to fail again . Quote Link to comment Share on other sites More sharing options...
Escape Posted December 14, 2020 Share Posted December 14, 2020 I do hope you have made an access hatch under the rear seat, so you don't have to drop the tank again... Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted December 14, 2020 Author Share Posted December 14, 2020 6 hours ago, Escape said: I do hope you have made an access hatch under the rear seat, so you don't have to drop the tank again... Nope ! Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted October 30, 2021 Author Share Posted October 30, 2021 One year on & I have to change this pump as it cant get up the hills any more , I am going on Escapes advise & go through the floor under the rear seat to get to it this time & wondered if anybody has any more advise , pictures , and/or measurements as to the location of the pump & where to start cutting the floor out , pictures would be best . Regards Paul . Quote Link to comment Share on other sites More sharing options...
Escape Posted November 1, 2021 Share Posted November 1, 2021 No pictures, but I have done this a couple of times now: - cut the insulation and carpet inside the right rear seat mounts at the sides and front and peel it away to expose the floor - grind (carefully) through both high areas closest to the seat mounts, preferably with a small disc so you can't slide through too deep - drill out the spot welds at the front and fold back the floor section - I use screws at the front with kit and tape to cover the cuts when reassembling, double sided tape or carpet adhesive can be used for the trim Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted November 1, 2021 Share Posted November 1, 2021 3 hours ago, Escape said: No pictures, but I have done this a couple of times now: - cut the insulation and carpet inside the right rear seat mounts at the sides and front and peel it away to expose the floor - grind (carefully) through both high areas closest to the seat mounts, preferably with a small disc so you can't slide through too deep - drill out the spot welds at the front and fold back the floor section - I use screws at the front with kit and tape to cover the cuts when reassembling, double sided tape or carpet adhesive can be used for the trim There is a video on Youtube a swede doing it on a Diesel. He gives the dimensions. I thought about doing it on my 4.6 petrol then I remembered I barbequed a P38 last year draini9ng the fuel tank and opted to take the tank out instead Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted November 2, 2021 Author Share Posted November 2, 2021 On 11/1/2021 at 1:38 PM, Escape said: No pictures, but I have done this a couple of times now: - cut the insulation and carpet inside the right rear seat mounts at the sides and front and peel it away to expose the floor - grind (carefully) through both high areas closest to the seat mounts, preferably with a small disc so you can't slide through too deep - drill out the spot welds at the front and fold back the floor section - I use screws at the front with kit and tape to cover the cuts when reassembling, double sided tape or carpet adhesive can be used for the trim On 11/1/2021 at 5:10 PM, Simon_CSK said: There is a video on Youtube a swede doing it on a Diesel. He gives the dimensions. I thought about doing it on my 4.6 petrol then I remembered I barbequed a P38 last year draini9ng the fuel tank and opted to take the tank out instead Thanks for the replies lads , just what I was after , I shall have a go at it this weekend weather permitting . Quote Link to comment Share on other sites More sharing options...
