92a Posted March 8, 2020 Share Posted March 8, 2020 I need to do another set of swivels, last time I used all EAC parts stuff at the top and Timken bearings in the bottom but I found that I needed almost no shims so no chance to "take out" any for future adjustments, wonder what brand others have used and would recommend? (I stripped an old one today and that had loads of shims and it got me wondering ) and yes I did put the little fibre discs in , Angus Quote Link to comment Share on other sites More sharing options...
lo-fi Posted March 8, 2020 Share Posted March 8, 2020 The EAC railcos are the best I've found. Mine came with two thicknesses of washer, which on my castings required using the thinner one. Sounds like you'd want the thicker option. Can't go wrong with Timken either. Quote Link to comment Share on other sites More sharing options...
92a Posted March 9, 2020 Author Share Posted March 9, 2020 Thanks LoFi, I have emailed them and I’ll post up any response Quote Link to comment Share on other sites More sharing options...
lo-fi Posted March 9, 2020 Share Posted March 9, 2020 Mine were for series, but they may be the same part. I ended up turning down the ends of the pins as I needed quite a stack of shims even with the thin washers. The fault there was the pins being too long, though, so worth checking yours for wear. Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 9, 2020 Share Posted March 9, 2020 I found some genuine ones on Ebay. I see them come up a fair bit. Mav Quote Link to comment Share on other sites More sharing options...
mickeyw Posted March 9, 2020 Share Posted March 9, 2020 It's been at least 15 years since I rebushed my old 90 in this way. I had a similar problem (no shims needed) and ended up fitting 2 thrust washers in each side. This wasn't ideal as I found myself having to make extra shims up to get the preload right. 1mm steel IIRC. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 9, 2020 Share Posted March 9, 2020 I can't remember what brand they were, but the last two complete kits I've bought have come from Bearmach. I personally wouldn't be too worried if they don't require shims. As they wear and need shims they'll be wearing the diameter too so I'd just replace them when they need it. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted March 10, 2020 Share Posted March 10, 2020 22 hours ago, landroversforever said: I can't remember what brand they were, but the last two complete kits I've bought have come from Bearmach. I personally wouldn't be too worried if they don't require shims. As they wear and need shims they'll be wearing the diameter too so I'd just replace them when they need it. Ross, you take shims OUT as they wear to add swivel preload, hence it being a problem if you can't have a stack of shims in there when new 😉 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 10, 2020 Share Posted March 10, 2020 Doh! That's what I meant! I missed the taking out bit! Quote Link to comment Share on other sites More sharing options...
