Failed brake light
remove the 2 screws from light unit, extract it from the body, then on the end where the wires are, twist the black bit while holding the lens, the black part is the bulb holder, once out of the lens body you can change the 2 filament bulb. then refit the 2 parts together & refit to vehicle.
 Share
