western Posted March 14, 2020 Author Share Posted March 14, 2020 Not yet, can't do that until transfer box is detached & on the floor, hopefully get that far tomorrow. Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2020 Author Share Posted March 17, 2020 Transfer box off, intermediate shaft & gears out, bearings removed, No big damage to transfer case, Only damage is the rear bearing which has broken up, front bearing is in one piece but had roller damage, Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2020 Author Share Posted March 17, 2020 Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2020 Author Share Posted March 17, 2020 Off to see my local LR parts man now to spend some dosh on new parts. 1 Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 17, 2020 Share Posted March 17, 2020 The inner ring of the bearing must have turned for some time. Didn't that make noise as well? Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2020 Author Share Posted March 17, 2020 Can't say I noticed it getting noiser than normal, the bearing cage is non existent, been cleaning inside the case with brake cleaner got a lot of rubbish out. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 17, 2020 Share Posted March 17, 2020 You must have a guardian angel, it is amazing there is so little damage considering what happened. Quote Link to comment Share on other sites More sharing options...
western Posted March 17, 2020 Author Share Posted March 17, 2020 Got a tiny burr to remove on the casing on edge of the intermediate shaft rear hole on inside face, the big magnetic plug & the standard magnetic drain plug saved the day I think. 1 Quote Link to comment Share on other sites More sharing options...
bodumatau Posted March 18, 2020 Share Posted March 18, 2020 22 hours ago, western said: Transfer box off, intermediate shaft & gears out, bearings removed, No big damage to transfer case, Only damage is the rear bearing which has broken up, front bearing is in one piece but had roller damage, smooth the sharp edges off with some 1000grit sandpaper and they good to go again, I say put them back in....they didn't seem to be making much noise anyway 🤷♂️ Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 18, 2020 Share Posted March 18, 2020 I wouldn't just to save 28,- ... only on a journey, where I can get no parts https://www.ashcroft-transmissions.co.uk/diy-rebuild-kits/lt230-rebuild-kits/lt230t-intermediate-shaft.html Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2020 Author Share Posted March 18, 2020 Already ordered a new shaft, bearings, locknut & spacer tube, got the gaskets & O ring seals yesterday. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 18, 2020 Share Posted March 18, 2020 I think @bodumatau was making an attempt at sarcasm ;) Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2020 Author Share Posted March 18, 2020 Just picked up the new parts, so the resurrection of my LT230 can commence soon. 1 Quote Link to comment Share on other sites More sharing options...
western Posted March 18, 2020 Author Share Posted March 18, 2020 New intermediate shaft, bearings, spacer tube & the gears set are fitted, waiting for a spring balance delivery tomorrow so I can set the preload correctly which will partly collapse the spacer tube then the shaft nut can be staked in place, I chopped the head & tail off the old intermediate shaft to make a dummy shaft to assist with fitting gears, bearings & spacer, the tapped the new shaft through to secure them all in the casing. 1 Quote Link to comment Share on other sites More sharing options...
Peaklander Posted March 19, 2020 Share Posted March 19, 2020 Good luck with the checks and final bits of re-assembly Ralph. Hope you get it lifted back up and on without too much of a struggle. Guess you will be upside down underneath reaching up? 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted March 19, 2020 Share Posted March 19, 2020 Ralph, unless you've got a jack here's a method I found quite useful when fitting my transfer box on my own. I put two ladders outside each front door ratchet strapped to the chassis. I then placed an old fence post (4x4") through the windows supported on the ladders. That way I could put a small pulley block (about £10 from Amazon) on the post and tied off to a seat base in the back - was invaluable in lifting it and holding it in place whilst I went about shoving it into place. 1 Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2020 Author Share Posted March 19, 2020 I'm waiting on 2 deliveries one is oil seals for the main shaft on main gearbox & transfer box, other is a spring balance so I can set the intermediate gear bearing preload, I haven't got space for ladders like that Ed, I do have a extra pair of hands available, so we can jack TB up, with a strap around it from above, I have 2 long studs in main gearbox rear face ready to help guide TB in to place. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted March 19, 2020 Share Posted March 19, 2020 Really - you mean you can't open the doors? Admittedly mine were only two short ladders (each about 8ft tall). Perhaps I wasn't clear - they were vertical alongside the body - not sticking out so didn't even stick proud of the wing mirrors. Hence why I strapped them to the chassis leg underneath. Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 19, 2020 Share Posted March 19, 2020 if you want to replace both the front and rear seal of your main gearbox, take care of the gasket on the front. I found, that they often have different thickness and that is interesting for endfloat of the main shaft Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2020 Author Share Posted March 19, 2020 53 minutes ago, Ed Poore said: Really - you mean you can't open the doors? Admittedly mine were only two short ladders (each about 8ft tall). Perhaps I wasn't clear - they were vertical alongside the body - not sticking out so didn't even stick proud of the wing mirrors. Hence why I strapped them to the chassis leg underneath. Ah, I thought you meant they were lengthways from the doors, anyway I haven't got a 2 part ladder to try it. We will get it in, I' did it back in 2008 when this LT230 was fitted Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2020 Author Share Posted March 19, 2020 53 minutes ago, Sigi_H said: if you want to replace both the front and rear seal of your main gearbox, take care of the gasket on the front. I found, that they often have different thickness and that is interesting for endfloat of the main shaft It's just the mainshaft rear seal on R380 & the front seal on LT230, where the 2 meet together, they are probably ok, but as its apart, its easy o swap for new seals, then I don't have to touch them again. Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2020 Author Share Posted March 19, 2020 spring balance scale has arrived so now I can get this done ----------------------- Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2020 Author Share Posted March 19, 2020 Well got the above done, the torque at the nut is as mentioned in the text ^^^^^^ so the big sump is refitted, I can't move forward as I'm waiting on the 2 oil seals to be delivered tomorrow, then TB can be lifted & bolted back in to 110. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted March 19, 2020 Share Posted March 19, 2020 Did you have to buy the service tool for the intermediate shaft torque measurement, or did you improvise somehow? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted March 19, 2020 Share Posted March 19, 2020 @cackshifter - he'd ordered a spring balance to do it. Quote Link to comment Share on other sites More sharing options...
