Green200tdi Posted March 14, 2020 Share Posted March 14, 2020 So my head lights are playing up dim dip won’t go off even with ignition off and switch off and head lights won’t come on, ive removed both fuses for now as it’s raining, is this the relay behind the dash or the one on the o/s inner wing What’s at fault? Quote Link to comment Share on other sites More sharing options...
western Posted March 14, 2020 Share Posted March 14, 2020 pull the pink dim dip relay & fit a jumper wire between the 2 blue/red trace wires in relay socket, that will get the headlights off & return to normal operation. Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted March 14, 2020 Author Share Posted March 14, 2020 3 hours ago, western said: pull the pink dim dip relay & fit a jumper wire between the 2 blue/red trace wires in relay socket, that will get the headlights off & return to normal operation. Cool thanks Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted March 15, 2020 Author Share Posted March 15, 2020 Well found my problem with the dim dip and why head lights are staying on seems the contact had rusted it’s self together,😳 relay full of water and been that way for a while as it’s rusty, so using a thick wire to bridge the lights all is ok now thanks Ralph 👍 see photos Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2020 Share Posted March 15, 2020 Glad you found the fault & fixed it. Quote Link to comment Share on other sites More sharing options...
