Francisco Trigo
"3 Friends" on LD Discovery Td5
Good afternoon everyone,
I would like to share with you a problem that, according to the research I have done, is transversal:
I have a Discovery II TD5 from 2000, and I have had the problem of "3 friends", I was told that the problem has the code "016" and when the error is eliminated, I can walk normally without having the lights on of the "3 friends".
I have read here that the problem may be with the "suttle valve" valve on the ABS module or the wheel sensors.
I would like to have your opinion and how I start to solve the problem.
Thanks for the tips.
Francisco.
Share this post
Link to post
Hi. that "016" must haveĀ a description, without that it's irrelevant but once the description is revealed the answer will come
Share this post
Link to post
