WindscreenMan Posted March 26, 2020 Share Posted March 26, 2020 Hello. Hopefully a very simple question... How thick in mm is a laminated Defender windscreen please? And how about height and width of the screen? Answers VERY gratefully received many thanks! Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 27, 2020 Share Posted March 27, 2020 Laminated screens are normally 6.4mm think from memory. My ibex one is and the last defender screen I did felt the same. Side windows are normally toughened and only 4mm. I'll try to measure a screen later. Mike Quote Link to comment Share on other sites More sharing options...
WindscreenMan Posted March 27, 2020 Author Share Posted March 27, 2020 Thanks Mike if you can measure the height and width of the windscreen that’d be great. Obviously thickness might be more difficult but appreciated if you can confirm the 6.4mm too. Cheers! Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted March 28, 2020 Share Posted March 28, 2020 Just from my experience: Do not cut the wind screen from wood. Your wiper blades will be destroyed soon. Take sheet metall ... 🤣🤣 Quote Link to comment Share on other sites More sharing options...
ballcock Posted March 28, 2020 Share Posted March 28, 2020 1 hour ago, Sigi_H said: Just from my experience: Do not cut the wind screen from wood. Your wiper blades will be destroyed soon. Take sheet metall ... 🤣🤣 If you use marine ply and varnish the outside you won't need the wipers. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted March 29, 2020 Share Posted March 29, 2020 430mm high 1357mm wide at the top 1417mm wide at the bottom All measurements are approximate edge of glass. Mike Quote Link to comment Share on other sites More sharing options...
