steve200TDi Posted April 4, 2020 Share Posted April 4, 2020 2 minutes ago, landroversforever said: Another vote for starret here. Unless you've got enough torque to run something like a rotabroach. Biggest problem with holesaws is most people run them waaaaaaay too fast. Which then causes them to both go blunt and wander around. Yep, slow as you can and plenty of cutting fluid. I never know if 3 in 1 oil (which is what i use, as I haven't got anything else) gives any benefit or that I should invest in some proper cutting fluid which is thicker. Steve Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 4, 2020 Share Posted April 4, 2020 1 minute ago, steve200TDi said: Yep, slow as you can and plenty of cutting fluid. I never know if 3 in 1 oil (which is what i use, as I haven't got anything else) gives any benefit or that I should invest in some proper cutting fluid which is thicker. Steve Anything is good! Strangely one of the best for aluminium is isopropyl alcohol . RTD paste or fluid is a pretty good cutting fluid (smells nice when you get it hot too ). The main thing with a lot of the cutting fluids is that they're quite sticky so they stay on the cutter. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 4, 2020 Share Posted April 4, 2020 1 minute ago, landroversforever said: Anything is good! Strangely one of the best for aluminium is isopropyl alcohol . RTD paste or fluid is a pretty good cutting fluid (smells nice when you get it hot too ). The main thing with a lot of the cutting fluids is that they're quite sticky so they stay on the cutter. Oh yes, that's the stuff we have at work....nice smell! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted April 4, 2020 Share Posted April 4, 2020 Water is a plenty good enough lubricant for Ali, trouble is, it sends everything else rusty. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted April 6, 2020 Share Posted April 6, 2020 I use CT90 cutting paste - it liquifies as the cutter heats up and makes an amazing difference in my experience. Quote Link to comment Share on other sites More sharing options...
