croozir Posted March 30, 2020 Share Posted March 30, 2020 Hi All I have a problem with the gearbox can't get it into 1st gear. I found the circlip was off the mainshaft at the transfer box so i refitted it and got first gear again momentarily, then it wouldn't engage 1st again (even with the engine turned off)... I then removed the selector cover and found 1st gear synchro hub (baulk ring) badly burred at the square drive lugs. I need to remove the mainshaft to replace the 1st gear synchro hub. Has anyone removed the mainshaft through the transfer housing with the gearbox in situ. Or do I need to pull the whole box out many thanks Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted April 4, 2020 Share Posted April 4, 2020 For something that involved, I would be removing the gearbox as you don't want dust and dirt getting inside the box when you do the open heart surgery bit on it! Steve Quote Link to comment Share on other sites More sharing options...
croozir Posted July 6, 2020 Author Share Posted July 6, 2020 Torrington race between 1st gear had disintegrated, fibre oil pump drive at the layshaft stripped so not pumping oil Quote Link to comment Share on other sites More sharing options...
garrycol Posted July 6, 2020 Share Posted July 6, 2020 Replace the fibre oil pump drive with a metal one when the box is out. Quote Link to comment Share on other sites More sharing options...
croozir Posted July 17, 2020 Author Share Posted July 17, 2020 Thanks Garry I've got the STC metal gear and drive its all back together just about to put it back in happy days Quote Link to comment Share on other sites More sharing options...
