garryc Posted April 3, 2020 Share Posted April 3, 2020 I'm looking for some ideas please. Got a 300tdi (manual gearbox) pre-EDC and believed to be pre-immobiliser (no additional wires on fuel pump) which I'm fitting in my Lightweight. Its not run for nearly ten years - I know; usual rebuild timescale.. Am using electric inline pump so lift pump shouldn't be an issue. I've got fuel all the way to the banjo coming in to the top of the pump and I've taken the boost pin cover plate off and there's fuel going in as the diaphragm is wet. I've cracked off an injector pump (no 1) but there is no fuel coming out. I've fitted a brand new shut off solenoid and it's clicking nicely. I've even taken a feed direct from battery just to eliminate any ignition switch issues so I know it's got voltage when cranking. But i'm getting no fuel when I turn the engine over. I've exhausted all my ideas. Hoping one of you more experienced gentlemen can suggest where I'm going wrong. Thank you Quote Link to comment Share on other sites More sharing options...
Escape Posted April 3, 2020 Share Posted April 3, 2020 There is a bolt in between the outlets for the injector pipes on the rear of the pump. Take it out (some diesel will/should spill), that will give you access to the injection plunger. If you turn the engine by hand with a clean welding rod or something pushed to the plunger, you should see it move a few mm. If it doesn't, the high pressure stage isn't working. We've spent quite some time diagnosing a similar problem in a Range Rover P38, turned out the plunger had broken! If you want, I can send you a manual for the VE injection pump, very helpful to understand its workings and how to diagnose it. Filip Quote Link to comment Share on other sites More sharing options...
garryc Posted April 3, 2020 Author Share Posted April 3, 2020 That would be really helpful. Thank you. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted April 4, 2020 Share Posted April 4, 2020 remove the fuel return pipe banjo on the back of the pump and clean out the bleed hole in the banjo bolt. If this is blocked ( can clog easily) the pump air locks Quote Link to comment Share on other sites More sharing options...
