defender dinky Posted April 7, 2020 Share Posted April 7, 2020 Hi, defender 110 project, so part have come from various vehicles mainly ebay, think bulkhead was off 300tdi some electrics come with it, question is three switches by your right knee I have internal light, and hazards switch, one nearest steering wheel blanked off but inside is connector block for a switch same as others it has white wire and a white/green trace wire what is this switch for, dd Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 7, 2020 Share Posted April 7, 2020 Heated rear window in mine. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 7, 2020 Share Posted April 7, 2020 I think it depends on which wiring loom you have and the spec of the truck it came from . My 110 200 tdi had hazards , rear heated screen , and interior lights , but I think from the 300 tdi did away with the interior light switch there and moved the fog light switch down there , I can check tomorrow as I have a 300 tdi wiring loom on the floor in the shed . Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2020 Share Posted April 8, 2020 On a 300tdi they will be rear fog light, hazard lights & rear window heater (if fitted). Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 8, 2020 Share Posted April 8, 2020 Just checked mine and as western said above , I’ve got that plug too it’s for the rear heated screen. here’s all three, heated screen , fog light , hazards, hope this helps. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 8, 2020 Author Share Posted April 8, 2020 Yes, first photo white/green trace, heated rear window, my fog light is on the steering column, in its place is the internal light, thks dd 1 Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 8, 2020 Share Posted April 8, 2020 The easiest way to find out what the wires do http://www.expeditionlandrover.info/Lucaswirecode.htm Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 8, 2020 Author Share Posted April 8, 2020 Hi, can't see white/green trace on that wiring chart? What model is it for, Dd Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2020 Share Posted April 8, 2020 The rear heater & rear wash wipe are on a supplement diagram, not all vehicles had those circuits fitted. Quote Link to comment Share on other sites More sharing options...
