tweetyduck Posted April 11, 2020 Share Posted April 11, 2020 Heck is a long time since i've needed to ask you Gurus anything. Intermittently my Starter spins but doesn't punch out. Upon removal it works perfectly on the bench when using a battery jump leads. I've cleaned up the insides and lubricated the solenoid with Graphite spray and its doing it again. Its of course a 24V but i doubt that makes any difference. The flywheel teeth look fine, as does the teeth on the motor. Question is, i suppose is that within the wiring on a 300Tdi would this (spin but no punch out) happen for ANY other reason other than it being the starter itself. By this i mean could the ignition switch, associated wiring or Starter Relay ever be able to make a motor spin but not punch out? I think not but i'm going to ask anyhow Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted April 11, 2020 Share Posted April 11, 2020 Pre-engaged, by "punch out" you mean release from the starter ring when power to the starter motor is turned off? Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 11, 2020 Author Share Posted April 11, 2020 motor just spins...solenoid does not "punch out" the spinning bit. So it just sits there spinning. Never engages with flywheel as its just spinning. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted April 11, 2020 Share Posted April 11, 2020 As I assume this is a pre-engaged, the starter motor should not spin until the solenoid has reached the end of travel and engaged (as that is where the contact that put power to the starter motor). Is it completing travel too early? Peter Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted April 13, 2020 Author Share Posted April 13, 2020 its not travelling as all it seems. Just spining Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted April 13, 2020 Share Posted April 13, 2020 Is that the problem? The solenoid should reach the end of travel (fully engaged) before the power is applied, so it sounds as if there is something wrong with the electrics in the starter motor. Quote Link to comment Share on other sites More sharing options...
western Posted April 13, 2020 Share Posted April 13, 2020 200tdi starter was doing that, not engaging but spinning when started, I replaced the starter with a new item & it's been fine since, so reckon it could be just worn out brushes. Quote Link to comment Share on other sites More sharing options...
ballcock Posted April 13, 2020 Share Posted April 13, 2020 4 hours ago, Puffernutter said: Is that the problem? The solenoid should reach the end of travel (fully engaged) before the power is applied, so it sounds as if there is something wrong with the electrics in the starter motor. It could be the pivot pin worn at the dog gear end, the solenoid has full travel but doesn't engage the drive cog. but as said the starter motor should not spin until the drive cog engages with the fly wheel. 1 Quote Link to comment Share on other sites More sharing options...
Stephenc Posted May 10 Share Posted May 10 I'm a bit late to the party on this one, but having done a little reading, as I currently have the same problem I think the issue may be the Bendix clutch. It's likely that the solenoid nis correctly engaging the starter, but as the Bendix clutch is worn / failing the shaft is spinning freely rather than driving the Bendix. Mine was starting first time every second turn of the key, but it's now every third! Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted May 13 Share Posted May 13 It's not always the case that the motor doesn't turn until the pinion is extended. Many solenoids earth via the motor windings so that the motor spins at reduced speed and power enabling the teeth to align before full power is applied. I had the same fault on my previous defender due to a sticking solenoid. 1 Quote Link to comment Share on other sites More sharing options...
