Range Rover Classic headlamp Washer Jets
Darren Roberts
 Share
Hi all,
1992 Classic hard dash SE. I'm trying to sort out some issues with the electrics. I'm trying to get the headlamp washers to work. I've got main washers, rear tailgate washer but not head lamp washers working.
I've check on the fuse board on the dash (row B fuse #6 - getting power and fuse ok). If I connect pump directly to the battery then it runs and pumps ok. So I'm assuming it's a relay issue. Trouble is that the wiring colours under the dash to the relay blocks don't match any of the colours mentioned in the 1991 factory workshop manual I've got.
Does anyone have a diagram for 1992 please? I think I've also got issues with the interior lights and heated screen, again I think its relay issues as all fused etc. ok but again can't identify the correct relay slots.
thanks in advance
Darren
 Share
