neilc Posted April 14, 2020 Share Posted April 14, 2020 I've purchased a new Alternator for my 2.25 petrol series 3 ( correct part ) , the bladed part seems to drag on the body as it spins ( by hand , I haven't installed yet ) is this correct ?, does the G force of opeation push it away from the body ? Any advice would be appreciated , thanks Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 14, 2020 Share Posted April 14, 2020 That's not right, got a picture? Quote Link to comment Share on other sites More sharing options...
Wytze Posted April 14, 2020 Share Posted April 14, 2020 My mate had that to.. He pulled it apart, because he needed it to drive again. The bearing in the front cover should be blocked by some small screw's . In his, there was nothing to keep the bearing locked. Could be the same problem? Quote Link to comment Share on other sites More sharing options...
neilc Posted April 14, 2020 Author Share Posted April 14, 2020 Ill put a picture on in the morning , thanks Quote Link to comment Share on other sites More sharing options...
neilc Posted April 15, 2020 Author Share Posted April 15, 2020 Is it just a case of putting a thick washer between the collar and the fan ? Quote Link to comment Share on other sites More sharing options...
Wytze Posted April 15, 2020 Share Posted April 15, 2020 Can you pull the shaft further towards you from that side? Quote Link to comment Share on other sites More sharing options...
neilc Posted April 15, 2020 Author Share Posted April 15, 2020 Nope , the shaft and collar can't be adjusted ? Quote Link to comment Share on other sites More sharing options...
Wytze Posted April 15, 2020 Share Posted April 15, 2020 Not sure, could be that a collar is in the wrong place.. but just to be safe. Stack the shaft with washers untill the nut still can go on. And turn it tight. To make sure that the shaft is fully seated. Quote Link to comment Share on other sites More sharing options...
neilc Posted April 15, 2020 Author Share Posted April 15, 2020 I've sorted it , I was just attempting to put a spacer washer on it when I realised the spacer washer would need to have a notch cut out of it to get it over the little marker . Whilst using my dremmel to cut of the notch I had a thought . I put the fan part on a flat surface and realised that the middle was raised ( to be fair , I think it should be ) so I tapped the centre with a spanner and it levelled off. Now when I put the fan part back on it clears the body by approx 2mm , probably not the ideal solution but it worked , thanks for the advice . Quote Link to comment Share on other sites More sharing options...
Wytze Posted April 15, 2020 Share Posted April 15, 2020 Good to hear it's sorted Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 15, 2020 Share Posted April 15, 2020 Just for the future, That 'little marker' in the shaft is a Woodruff Key, they come in different shapes and sizes. The 'slot' in the fan and the pulley is a 'keyway'. Some times it's for clearance, as in the fan; sometimes it's for location, to stop the pulley slipping around the shaft when power is being transmitted via the drive belt. Glad you have found a solution. Regards. Quote Link to comment Share on other sites More sharing options...
neilc Posted April 15, 2020 Author Share Posted April 15, 2020 Has anyone got a diagram of where the bolts go on the Alternator please , its been so long since I've taken it out that I've forgotten , I know the ling bolt fixies the bracket to the block and the one on the Alternator fixes to that .The problem I'm having is that I then still have another long bolt that's about 3 inches and another 2 that are about half the size . Does the long bolt go straight through the alternator and the bracket or is this fixed with the two smaller bolts ? , I seem to have too many bolts , a diagram would be very much appreciated , I can't find one , thanks Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 15, 2020 Share Posted April 15, 2020 Any good? Quote Link to comment Share on other sites More sharing options...
neilc Posted April 15, 2020 Author Share Posted April 15, 2020 That's exactly what I needed , thanks . Quote Link to comment Share on other sites More sharing options...
Landrover17H Posted April 16, 2020 Share Posted April 16, 2020 (edited) I run a 17H which (I think) has a 55Amp jobby as stock, but when it went U/S threw on a 85Amp. They're all the same as far as I can make out. Just left or right hang. Like batteries, bigger is always better. Edited April 16, 2020 by Landrover17H Quote Link to comment Share on other sites More sharing options...
