Binnman Posted April 14, 2020 Share Posted April 14, 2020 Hi Guys, Need some guidance, please. I had noticed that the Brake Servo was cracked by one side of the Master Cylinder and I bought a replacement off eBay, using the year 1995 of my Defender 90 CSW for reference. The replacement Type 50 STC2879 (non ABS) arrived and was left aside until I had time to fit it. The Coronavirus has provided that time. But sadly, the replacement does not match what was in my wagon. Please see photos attached. Mine is on the right. All the L-R Spares listings I've seen say that a Type 50 is correct for my year/model. But it is not what I had. So, what servo do I need to buy, please? (Part number and type would be a big help; even bigger would be a link to the correct item!). Cheers, Ron /AKA Binnman Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2020 Share Posted April 14, 2020 Your existing servo should be STC442 a type 80 which is bigger diameter & thinner front to rear with the master cylinder studs offset & fitted to 200 & 300Tdi 90/110 with front & rear disc brakes. the earlier type 50 is a smaller diameter but thicker front to rear with master cylinder studs opposite horizontally. STC442 is now LR013488 --- https://www.brit-car.co.uk/product.php/102043/0/master_cylinder_brake_servo_assembly___defender_2007_onwards_less_anti_lock_braking_system_ Quote Link to comment Share on other sites More sharing options...
Binnman Posted April 14, 2020 Author Share Posted April 14, 2020 Thank you, Western; you are a Star as usual. Really appreciate your assistance as I was totally confused and afraid to order another in case I purchased another wrong one. Thanks again. Ron. Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2020 Share Posted April 14, 2020 Happy to help, hope you get the one you need. 1 Quote Link to comment Share on other sites More sharing options...
