Maz66 Posted April 14, 2020 Share Posted April 14, 2020 hi lads need some info on power steering conversion my series 3 has a 200 tdi i have the power steering pump. a p38 relay box .have been told i need a defender steering column have also head that discover1 steering set up will work i have a full D1 steering set up aswell i found a thread by smokey joe were he mentions but cant find it now typical any help appreciated Quote Link to comment Share on other sites More sharing options...
Jon White Posted April 14, 2020 Share Posted April 14, 2020 Either can be made to work, but the P38 setup is nicer and requires less hacking of the chassis. Quote Link to comment Share on other sites More sharing options...
Maz66 Posted April 14, 2020 Author Share Posted April 14, 2020 so i cant use the d1 with the p38 box i have to use the defender column ? Quote Link to comment Share on other sites More sharing options...
Jon White Posted April 15, 2020 Share Posted April 15, 2020 I was only talking Steering box. You could probably make the disco column work if you wanted to, just most people use a defender one as it bolts straight on. Quote Link to comment Share on other sites More sharing options...
Chicken Drumstick Posted April 15, 2020 Share Posted April 15, 2020 I used a Defender column. Pics in this thread: forums.lr4x4.com/topic/97313-modified-leafer-88-and-rebuild-with-upgrades/ Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 16, 2020 Share Posted April 16, 2020 I documented a P38 steering system I fitted to my 109 a bit over five years ago in my blog. It works brilliantly, using the P38 box, pump and lower column, and a Defender upper column and steering wheel. Feather light, but the same ratio as the original steering box so the same handling and feel. It’s all in the steering section of my blog - click my signature below to have a look. Quote Link to comment Share on other sites More sharing options...
jerboa Posted April 18, 2020 Share Posted April 18, 2020 Quick question re: the p38 steering box conversions. In using a defender steering column, does this mean there's no way the original steering wheel can be used? I rather like the Series wheel, and feel a defender one could look out of place in a series - although an early defender wheel would be OK I suppose... Thanks, Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 18, 2020 Share Posted April 18, 2020 If you use the correct era Defender column, the Series wheel will fit. It needs to be from the Tdi ere, with the big spongy two spoke wheel. But the column is longer and the switchgear fits differently. You can fit the original shroud and switches, but you’d need to be creative. The SIII steering lock and ignition switch will fit directly onto the Defender column, but that sets the top end closer to the driver. Whether you choose to modify the column to move the slot closer to the driving end to match the SIII distance, remove the steering lock parts to fit the assembly to a plain section of the column, or shorten the column outright is up to you. I didn’t want to cut and weld bits of steering column, so I ended up fitting Defender switches and shroud, even though I’d have preferred to keep the simple SIII parts if it had been viable for me. Quote Link to comment Share on other sites More sharing options...
jerboa Posted April 19, 2020 Share Posted April 19, 2020 On 4/18/2020 at 10:16 AM, Snagger said: If you use the correct era Defender column, the Series wheel will fit. It needs to be from the Tdi ere, with the big spongy two spoke wheel. But the column is longer and the switchgear fits differently. You can fit the original shroud and switches, but you’d need to be creative. The SIII steering lock and ignition switch will fit directly onto the Defender column, but that sets the top end closer to the driver. Whether you choose to modify the column to move the slot closer to the driving end to match the SIII distance, remove the steering lock parts to fit the assembly to a plain section of the column, or shorten the column outright is up to you. I didn’t want to cut and weld bits of steering column, so I ended up fitting Defender switches and shroud, even though I’d have preferred to keep the simple SIII parts if it had been viable for me. Thank you Snagger..! 👍 Quote Link to comment Share on other sites More sharing options...
