hurbie Posted April 18, 2020 Share Posted April 18, 2020 hello all , i need a little help from the serie's goeroes , i recently accuired a large stock of NOS landrover parts (the owner closed his shop , and there was nobody interested to take his inventory, so i made hime an offer , and he said yes to it ......) most of the parts are labeled , so no problem finding wat it is , but there is the odd one , misplaced or lost it's number , so there i need you knowledge ! first question is this longer "crankshaft vibration damper driving flange" , the number of the shorter on is 09017 , and the longer one was mixed in with the shorter one's . Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 18, 2020 Share Posted April 18, 2020 What engine do you think 09017 fits? Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 18, 2020 Author Share Posted April 18, 2020 i got some info from this website : https://www.lroe.co.uk/crankshaft-vibration-damper-driving-flange-09017 serie's 1 1600 and 2.0 "siamese" petrol Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 18, 2020 Share Posted April 18, 2020 Now you have given us that essential clue it can be found in the parts book as Driving Flange Crankshaft Damper 2 Ltr. Diesel 247674. Both Craddocks & Blanchards recognise the number. Regards Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 18, 2020 Author Share Posted April 18, 2020 that's really great , does that make it a serie's 1 or 2 part . i can't find the number in the serie's 1 parts manual ? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 18, 2020 Share Posted April 18, 2020 I 'think' the 2 litre diesel is mainly a Series 1 engine, although it might have been Series 2 also. If so, the 2.25 diesel would have come in with the Series 2A. I looked in this listing; 4th Ed. June 1956, 2nd rev, Oct. 1961. Part 4107, Diesel Engine 2 litre, page 49. The diagram clearly shows the long version, and it's numbered separately in the associated number list. It's also in the numerical Index. Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 18, 2020 Author Share Posted April 18, 2020 very happy with this result , i'think i will have a new one tomorrow . Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 19, 2020 Author Share Posted April 19, 2020 next one 🙂 2 different shaft's , one has a hole on the end , the other one has a keyway (don't know if this is the correct term) they were in a somewhere around number 219986. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted April 19, 2020 Share Posted April 19, 2020 How much confidence do you have in the accuracy of the part number 219986? I have zero confidence. How long are the shafts? What is the diameter of the ends with the keyway or hole in? What is the diameter of the splined sections? I'm assuming both shafts are the same diameters at these points. Regards. Quote Link to comment Share on other sites More sharing options...
Landrover17H Posted April 19, 2020 Share Posted April 19, 2020 Brilliant thread. I have to chuckle at myself. How close to truly tragic does it have to get? Don't ask me why, I actually know and care about this sort of thing? Count me in. Where's the popcorn? 1 Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 19, 2020 Author Share Posted April 19, 2020 (edited) 2 hours ago, David Sparkes said: How much confidence do you have in the accuracy of the part number 219986? I have zero confidence. How long are the shafts? What is the diameter of the ends with the keyway or hole in? What is the diameter of the splined sections? I'm assuming both shafts are the same diameters at these points. Regards. the trouble with this "batch " of parts , the really old one's have parts from rover/mg/jaguar mixed in , so some numbers have no landrover resemblance. 219986 turned out to be a bush set for a brake pedal from a rover P4 i mentioned the number because the shaft is probebly in the same "range" of partnumbers , so lets say between 219000 - 221000 i'l meassure the shaft's tomorrow . Edited April 19, 2020 by hurbie Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2020 Share Posted April 19, 2020 a lot of Rover car parts were used in Sereies 1 & 2/2a vehicles, Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 22, 2020 Author Share Posted April 22, 2020 On 4/19/2020 at 7:00 PM, David Sparkes said: How much confidence do you have in the accuracy of the part number 219986? I have zero confidence. How long are the shafts? What is the diameter of the ends with the keyway or hole in? What is the diameter of the splined sections? I'm assuming both shafts are the same diameters at these points. Regards. off coarse i forgot my calipers for the second day , so i have to "guesstimate" the shaft is 20 cm long , diameter of the splined section is more or less 15mm (is that 9/16th ? ) , the 2 shaft's look identical except for the end with the hole or the keyway . i came across various parts for PTO unit's in the same partnumber range , so it may be something for these ... Quote Link to comment Share on other sites More sharing options...
steve b Posted April 22, 2020 Share Posted April 22, 2020 2A/B Forward control gearshift remote linkage box ? I've not seen that part in any PTO configurations I've come across cheers Steve b Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 22, 2020 Author Share Posted April 22, 2020 2 minutes ago, steve b said: 2A/B Forward control gearshift remote linkage box ? I've not seen that part in any PTO configurations I've come across cheers Steve b that could very well be it , i'll see if i can get a parts manual for the 2a/b (1 only have one for the military FC ) , and there's a front door for a 2A/B in the inventory ! Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 26, 2020 Author Share Posted April 26, 2020 so , after flipping many page's in various parts manuals , i think i finally found the axles ... the one with the woodruff key is for a LHD serie's 1 clutch fork ( https://www.johncraddockltd.co.uk/231942-splined-cross-shaft-for-clutch-fork-from-gb-016112987-lhd.html ) the other one i can't find , but since in holland we drive on the left side , i think it is 218028 , so old and new LHD cross shaft axle for a serie's 1 clutch . pfff on to the next one 😉 Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 30, 2020 Author Share Posted April 30, 2020 so , next one : the bottom springclip is partnumber 347668 , and is used for fitting the front grill on a serie's 3 (not a v8) , the 2 clips above it where in the same partsbin but look different , i can't find a "updated" number so it must be something else .... any thought's ? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 30, 2020 Share Posted April 30, 2020 Reminds me a bit of the clips on my Series III that held the distributor cap on. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 30, 2020 Share Posted April 30, 2020 Certainly the top two are for the distributor, no idea on the others. Quote Link to comment Share on other sites More sharing options...
hurbie Posted April 30, 2020 Author Share Posted April 30, 2020 found this : the series 1 and 2 use a lucas clip on the distributor (LU 425765) or landrover number 245013 . some searching reviels this : http://www.distributordoctor.com/distributor-cap-clips.html and the 43D and 45D clips look like these .... no i only need to find if the serie's 1 and 2 used the 43/45D caps ... you guys are great !! Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 2, 2020 Author Share Posted May 2, 2020 next question , does anybody know how to tell apart the 6 cylinder cam follower's ? there are 4 different cam followers (531874/531873 and 536873/ 536872) , some bright eyed person threw them all in the same bin .... so far i can see i have 3 different type's , but maybee there's 2 that only slightly differ from eachother . so does anybody know how to identify these ? is it possible to sort them by "castingnumber" or does that have no meaning at all . at the moment the parts are covered in some preserving goo .... so very hard to see diffenences Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 2, 2020 Share Posted May 2, 2020 There are two types of left reaching and two of right reaching. They have different angles of reach. The last picture above shows this - the top left rocker in that photo has less bend in it than those in the bottom row. You'll be able to see which needs to go where by looking at the top of the head with the rocker shaft installed. You’ll see the lateral displacement between the centreline of each rocker position and the valve stems. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 18, 2020 Author Share Posted May 18, 2020 here we are again , this time it's wire's ... i have a number of wiring harness (88 petrol/diesel 109 diesel) and a mystery one , the numbers known are 589708 / 589705 / 589710 . the mystery one has number 589693 , there's also a lable from the manufacterer with a drawing number 51240733 and a date off 1975 , the cable looks like a chassis harness with some extensions at the rear . the serie's 3 manual doesn't list it , and a internet search doesn't show this number ... there's also a (to me) strange grey connector , maybee someone recognises this if need be , i can spread it out on the floor so you have a better look at the length . Quote Link to comment Share on other sites More sharing options...
steve b Posted May 18, 2020 Share Posted May 18, 2020 The grey connector is for the cable drive wiper motor , Series3 . cheers Steve b Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 18, 2020 Author Share Posted May 18, 2020 so at least it is a dash harness , i will lay it out on the floor , and see if i can make out LHD or RHD , is it normal for a serie's harness to have two purple wires without a bulletconnector ? Quote Link to comment Share on other sites More sharing options...
