hurbie Posted May 19, 2020 Author Share Posted May 19, 2020 could it be a chasis harness , with the connector for the rear wiper motor (don't know if this is the same as the front motor) , i can't find a parts diagram for a rear mounted wash/wipe system on a serie's 3 (i looked in the normal parts manual , and in the optional manual) maybee someone can identifie the wire colors from the picture's . Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 19, 2020 Author Share Posted May 19, 2020 Quote Link to comment Share on other sites More sharing options...
JPB1 Posted May 20, 2020 Share Posted May 20, 2020 Hi, I think it is a rear body loom from an early Range Rover. The purple wires will be for an interior light, the grey wiper motor plug for the rear wiper (Range Rovers used the some wiper system on the rear wipers as Series 3 Land Rover front wipers), and the heavy white/black cables for heated rear window. Other wires will be the feed to rear lights. I can't identify the part number as the RR Parts Manual just shows NLS (no longer supplied) - later models are part numbers PRC1105 and PRC3050. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 20, 2020 Author Share Posted May 20, 2020 thank you very much , i'll see if i can find a old range rover manual to verifi the number ... Quote Link to comment Share on other sites More sharing options...
steve b Posted May 21, 2020 Share Posted May 21, 2020 good call JBP1 My early parts book show up to and incl. suffix A 90575284 Suffix B only 589693 Suffix C & D 90623070 Suffix E onwards rear fog PRC3050 no rear fog PRC1105 cheers Steve b Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 21, 2020 Author Share Posted May 21, 2020 that's great news !! thanks for the effort guy's !! then it's time for the next one , a shaft from a gearbox , number is somewhere in the 500000-600000 range . if it is a shaft from a LT76 , it could be 576726 (it has writen "26" on the shaft with a felt pen) , that would make it a 1 ton shaft , does anybody know the difference between 576725 (normal) and 576726 (1 ton) ?? Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 22, 2020 Share Posted May 22, 2020 That’s definitely from an LT76, but the rear bearing area looks healthier than I remember, so that may be a difference. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 22, 2020 Author Share Posted May 22, 2020 i found the solution , after reading some more in the parts manual , the rear nut has 2 different numbers (217477 for normal , and 521633 for 1 ton) , so i can try witch one fit's . riddle solved ... on to the next one 🙂 Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 23, 2020 Share Posted May 23, 2020 I think it’s the 1-Ton shaft. Quote Link to comment Share on other sites More sharing options...
