kevin50 Posted April 25, 2020 Author Share Posted April 25, 2020 2 minutes ago, western said: the earth wires just go to existing earth points at each set of lights, they can be secured by one bolt/nut tothe respective body area of the vehicle, rear earths are on top of the left & right rear wheelarch covered by the rear corner covers, the front lights go to a attachment on the front left & right inner wing vertical panel behind the front lights. Thanks Cant remember seeing any of these points, or can I just earth them to any good nut and bolt near where they go in. ?? Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2020 Share Posted April 26, 2020 On mine the earth for each set of rear lights is exactly that, a bolt/nut or big self tapping screw into the top face of the wheel arch, it's then hidden from view when the rear corner covers are fitted inside. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 26, 2020 Author Share Posted April 26, 2020 Well got all 4 indicators working, off the test on plug for switch, should be a case of just plugging the switch in now. Front ones fitted in place , need to run wires for the rears from loom in pic it is on the right side coming out of Chassis, I seem to be finding all the wires I need coming from it. Couldn't get side lights to work for some reason though. Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2020 Share Posted April 26, 2020 Where have all the rubber cased connectors gone ? good you got the indicators to work. front side light wires are LH -- red/black RH -- red/orange both have plain black earth wires, each side has seperate fuses in the fusebox under dash.. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 26, 2020 Author Share Posted April 26, 2020 21 minutes ago, western said: Where have all the rubber cased connectors gone ? good you got the indicators to work. front side light wires are LH -- red/black RH -- red/orange both have plain black earth wires, each side has seperate fuses in the fusebox under dash.. It was like that when I got it Mate, I taped the end all up to thread it back through Chassis, but all wires do seem to be there, touch wood. what do the rubber connectors look like ? Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2020 Share Posted April 26, 2020 they are moulded on to the ends of the looms, like the one on dash loom, You will have to source a suitable plug/socket to join the chassis loom fornt end to the main loom in the engine bay adjacent to the brake & clutch pedal housings. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 26, 2020 Author Share Posted April 26, 2020 (edited) 34 minutes ago, western said: they are moulded on to the ends of the looms, like the one on dash loom, You will have to source a suitable plug/socket to join the chassis loom fornt end to the main loom in the engine bay adjacent to the brake & clutch pedal housings. I have them in the Engine Bay already plugged together. My last pic above is from Rear where it comes out near rear crossmember. Would there have been one on here with another to plug in to ?? Edited April 26, 2020 by kevin50 Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2020 Share Posted April 26, 2020 Ah, no not at the rear right corner, the end fittings would be bullet connectors. I didn't notice the rear wheel & axle in the background of photo. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 27, 2020 Author Share Posted April 27, 2020 Swapped the harness for dash Dials back over to the original one, Now got Battery and Fuel dials working, so happy about that, All indicators work with the test wire rigged in to the Hazard plug whilst waiting for switch. But still none of the small bulbs light up in dials. will have another bit tinker tomorrow, with side lights, The Lone black wire is still there on this loom too, will try it to earths tomorrow. Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2020 Share Posted April 27, 2020 Probably need the dash/interior light switch to be fitted then, & make sure the top of the switch is in. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 27, 2020 Author Share Posted April 27, 2020 53 minutes ago, western said: Probably need the dash/interior light switch to be fitted then, & make sure the top of the switch is in. Dam forgot about that, Ive got the switch but still waiting for light and Hazard switch. 1 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 27, 2020 Author Share Posted April 27, 2020 Found a couple of good points to earth on the front for side lights and Indicators, but still struggling to find something near at the back. I did Shultz the rear tub before fitting so cant see any nice shiny clean bolts yet. Quote Link to comment Share on other sites More sharing options...
western Posted April 27, 2020 Share Posted April 27, 2020 in each rear corner where the body of the lights & electrical connections are, a bolt/nut through the horizontal face of the wheel arch will be OK as earth point. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 28, 2020 Author Share Posted April 28, 2020 20 hours ago, western said: in each rear corner where the body of the lights & electrical connections are, a bolt/nut through the horizontal face of the wheel arch will be OK as earth point. Ready to fit lights on tub now, its backed right up to wall so need to pull it forward to gat more room first, Some good progress today, got the hazard switch plugged in and all Indicators, and bulbs in dials work , there is a red / black coming from the switch and couple of small wires coming out where switches are, in pic 1 black and orange / white. Apart from that there are Numerous spare plugs of different sizes and colurs down in the lower dash where all wires are in pic 2, not sure if I need these as most things seem to be working. So far I have Working. Indicators fuel gauge heater blower motor wipers when I finally fit another wheel Lights on gauges I know where wires are for for washer bottle motor and roof light. Really need to know what the spare ones are for that are not plugged in to anything before I fit the Binnacle . Quote Link to comment Share on other sites More sharing options...
western Posted April 28, 2020 Share Posted April 28, 2020 The short red/black trace on the hazard switch plug hoes to one of the spade terminals on side of the switch, the other spade terminals should have the earth plain black wire on, this will operate the hazard switch internal red warning light when switched on. The white/orange trace wire is a spare 12v feed for air condition fitted vehicles, tape it up as its not required. Sounds like your day has been very productive,. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 28, 2020 Author Share Posted April 28, 2020 (edited) 15 minutes ago, western said: The short red/black trace on the hazard switch plug hoes to one of the spade terminals on side of the switch, the other spade terminals should have the earth plain black wire on, this will operate the hazard switch internal red warning light when switched on. The white/orange trace wire is a spare 12v feed for air condition fitted vehicles, tape it up as its not required. Sounds like your day has been very productive,. Thanks Mate, Finding it hard and tedious but getting there with help from you great people. Need a bulb for one of the dials, the small ones in pic , not sure what they are called or size, also which headlight bulbs do I need, there is a plug for one in drivers side so need to get one for other side. Edited April 28, 2020 by kevin50 Quote Link to comment Share on other sites More sharing options...
western Posted April 28, 2020 Share Posted April 28, 2020 Gauges use 1.2 watt capless 12 volt, you can get those in almost any motor factor or Halfords. Headlight bulbs are 55/65 watt H4 12volt. The plugs for headlight - - - - https://www.ebay.co.uk/b/h4-plug/bn_7024805166 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 28, 2020 Author Share Posted April 28, 2020 37 minutes ago, western said: Gauges use 1.2 watt capless 12 volt, you can get those in almost any motor factor or Halfords. Headlight bulbs are 55/65 watt H4 12volt. The plugs for headlight - - - - https://www.ebay.co.uk/b/h4-plug/bn_7024805166 Great Thanks Mate. 1 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 29, 2020 Author Share Posted April 29, 2020 Didn't have much time today, but tried side lights, left hand side works but can not get drivers side to work, orange / red nothing front or back, all fuses ok so not sure .if wires damaged somewhere, Not got a clue how to find it. Quote Link to comment Share on other sites More sharing options...
western Posted April 29, 2020 Share Posted April 29, 2020 Does each light work if you put the red/orange to positive on battery & plain black to earth/negative? Have you got good clean connections to each light? Did you have the main light switch on Can you get power at front & rear wires (coloured ones only) with one of these or similar tester https://www.halfords.com/tools/hand-tools/insulated-and-electrical-tools/halfords-advanced-circuit-tester-926782.html Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 29, 2020 Author Share Posted April 29, 2020 1 hour ago, western said: Does each light work if you put the red/orange to positive on battery & plain black to earth/negative? Have you got good clean connections to each light? Did you have the main light switch on Can you get power at front & rear wires (coloured ones only) with one of these or similar tester https://www.halfords.com/tools/hand-tools/insulated-and-electrical-tools/halfords-advanced-circuit-tester-926782.html Lights work off battery, Clean connections. Yes tried with main switch on. but only passenger side works. Can only get power on passenger side with test light Quote Link to comment Share on other sites More sharing options...
western Posted April 29, 2020 Share Posted April 29, 2020 Try a known new or working fuse in right side light in fuse box, & give the clips a clean with some fine emery cloth, could just be a poor fuse/dirty clips. the 2in orange hoop in photo other than examining the loom for broken wires or disconnected connections, without being with the vehicle its a bit difficult to see what's happening. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 29, 2020 Author Share Posted April 29, 2020 10 minutes ago, western said: Try a known new or working fuse in right side light in fuse box, & give the clips a clean with some fine emery cloth, could just be a poor fuse/dirty clips. the 2in orange hoop in photo other than examining the loom for broken wires or disconnected connections, without being with the vehicle its a bit difficult to see what's happening. Thanks Mate, Think your right about fuses as when trying them a couple were only lighting on one side which I thought were gone untill I pressed them in harder and they worked, so will give them a good clean first. es 1 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted April 30, 2020 Author Share Posted April 30, 2020 18 hours ago, kevin50 said: Thanks Mate, Think your right about fuses as when trying them a couple were only lighting on one side which I thought were gone untill I pressed them in harder and they worked, so will give them a good clean first. es Cleaned and New Fuses, all lighting up. I Can get Power from the rear red / orange but Not Front. Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2020 Share Posted April 30, 2020 Ah, well at least part of our fixed worked, there could be a break in the front wire then, try a new wire from the connection where the chassis loom & dash/main loom join to the sidelight that will give you a idea if the red/orange to the front is suspect, Quote Link to comment Share on other sites More sharing options...
