Gazzar Posted April 19, 2020 Share Posted April 19, 2020 Can relays be fitted in any orientation? Or do they have to be suspended, spades down? Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2020 Share Posted April 19, 2020 terminals facing down if fitted in engine bay is the best way as any water will drip off, if inside the cab/battery box/fusebox then sideways is ok, Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 19, 2020 Author Share Posted April 19, 2020 Cool, it's in the cab. Sloping back on the sloppy bit in the dash. Quote Link to comment Share on other sites More sharing options...
western Posted April 19, 2020 Share Posted April 19, 2020 That should be fine, my 110 has a relay in that area when it was built, I believe its the rear fog light relay or ecu as its called in the manual. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 19, 2020 Share Posted April 19, 2020 Some relays are sealed from the factory if you look at the base. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 20, 2020 Author Share Posted April 20, 2020 Thanks, I'll hopefully get this in sometime this week. Quote Link to comment Share on other sites More sharing options...
