Bigj66 Posted April 26, 2020 Author Share Posted April 26, 2020 4 minutes ago, Snagger said: I installed a 110 Salisbury axle on my 109, but it was an early version from a pre-Defender model. I installed discs on it using 90/110 front hubs, D110 discs, Discovery callipers, the 300Tdi calliper brackets and a mix and match of spacer washers between wheel bearing and hub nut. It works very well. That was for the rear axle? Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 26, 2020 Share Posted April 26, 2020 2 minutes ago, Bigj66 said: Does anyone know if the front half shafts on a coil axle are tapered like the series ones or straight between the splined sections? I don’t recall them being tapered on the 10-23 spline type. I think the later type may be slightly wasted to allow for a raised seal land. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 26, 2020 Share Posted April 26, 2020 Just now, Bigj66 said: That was for the rear axle? Yes. Front axle is a 200 Discovery unit with 300 callipers (same dimensions and pistons, just single line into each callipers like Defenders instead of dual line like earlier RRCs). Quote Link to comment Share on other sites More sharing options...
