ZF oil cooler pipe
Simon_CSK
The pipe that feeds the oil cooler from the underside of my ZF gearbox on my P38 is slightly kinked and is leaking. The pipe has a step in in to locate into the gearbox. can I seal the pipe with PTFE tape or a rubber o ring?
If it's leaking at the connection, a new O ring can only help. Maybe at some Loctite 577 or similar to fill (small) kinks. Or even liquid gasket. I wouldn't trust tape, I can't even get it to seal on water pipes half of the time (but that's probably just me 🙂 ).
