Adam001 Posted April 30, 2020 Share Posted April 30, 2020 Hi all, I'm fitting puma seats to the 2nd row of my defender 110. I've sourced all the bits I need but I'm a little stuck on seatbelts as I don't have any. My defender is a 1988 and I have 300tdi interior trims which would suggest I need BTR5779 on both sides. Question is, will these connect with the receivers on the seats or do I need EVL000080PMA/EVL000090PMA from the td5 or later still the EVL501580PMA from the puma, but I'm not sure if these later ones will mount on the C post. Anyone done it and know for sure? Adam Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2020 Share Posted April 30, 2020 Think you would be best to go with the right belts to match the receiver on the seats. http://cat.lrparts.ru/?category=57245 Defender 2007 on 2nd row outer seatbelt C post attachments item 1 in http://cat.lrparts.ru/?category=57229 looks pretty similar to the earlier vehicles for 110 fitting. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted May 1, 2020 Author Share Posted May 1, 2020 Yeah that's what I was thinking but I imagine they must have changed the brackets for a reason, not cheap these belts so want to at least try and get the right ones. Can always return I guess. I will probably default that way if at a loss. Anyone else done it at all? Quote Link to comment Share on other sites More sharing options...
Adam001 Posted July 30, 2020 Author Share Posted July 30, 2020 For reference, the earlier BTR5779 belts clip into the puma seats no problem. 1 Quote Link to comment Share on other sites More sharing options...
