Tapping into Reverse Light Circuit
I bought an Optimill Number Plate Light with built in camera and have run the wire from the dash to the camera. I now need to tap into the the reverse light. Seeing that the supplied loom has the wires for the reverse light near the rear, I was thinking of conecting the wire near the reverse light itself. However the wires and rear of the reverse light are tucked away behind a panel in the wheelarch. Would it be better to extend the wire and attach it to the reverse light switch, or do you reckon I should stick to my original plan?
