hurbie Posted May 1, 2020 Share Posted May 1, 2020 hello all , i got my radius arms back from sandblasting and painting , so fitted the remaining parts , to keep everything together. i ordered new nuts (M20 NY120041) these fit the threads but are very sloppy fit , i guess some 1-1,5 mm "play" on the threads .....this can't be right . is it possible they fitted imperial radius arms to this 110 (1985) ? i'm not good at measuring imperial but it looks like 3/4" inch ... so wat nut to order ?? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 1, 2020 Share Posted May 1, 2020 (edited) Nope. Early arms use M20 according to the earliest parts catalog. Edited May 1, 2020 by Red90 Quote Link to comment Share on other sites More sharing options...
MattMatt Posted May 1, 2020 Share Posted May 1, 2020 (edited) Early RRCs are 5/8 UNC, (just done mine) but I understand the change over to metric wasn’t terribly organised Sorry meant UNF not UNC Edited May 1, 2020 by MattMatt Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 1, 2020 Share Posted May 1, 2020 ¾ of an inch is 19.05mm and threads are never oversize. M20 is correct and being commercial parts the threads will be sloppy, however what your measuring there looks very under size to me. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 1, 2020 Author Share Posted May 1, 2020 i now see the picture bigger as on my phone , the thread looks indeed tapered .. i'll try again with a decent nut (the one i ordered were Br*tpart , so who knows ....) Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 1, 2020 Share Posted May 1, 2020 That'll be Chinese metric then 😂 Mo Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted May 2, 2020 Share Posted May 2, 2020 (edited) 10 hours ago, Mo Murphy said: That'll be Chinese metric then 😂 Mo Must be the metric, they landed on the dark side of the moon with ... 😂 😅 Measure the length of 10 turns of the thread. If it is 25 mm, it is M20. Edited May 2, 2020 by Sigi_H Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 2, 2020 Share Posted May 2, 2020 How far are you putting the nut on? The first bit of thread is very corroded and undersize. Quote Link to comment Share on other sites More sharing options...
neil110 Posted May 2, 2020 Share Posted May 2, 2020 There are 2 different types of lower links, hollow and solid. They MUST NOT be mixed. NTC4720 solid NTC8328 hollow However there is only 1 part No for the nut NY120041l which supercedes to NY120064 https://www.brit-car.co.uk/product.php/418550/0/nut_m20_nylock Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 2, 2020 Share Posted May 2, 2020 8 hours ago, Sigi_H said: Must be the metric, they landed on the dark side of the moon with ... 😂 😅 Measure the length of 10 turns of the thread. If it is 25 mm, it is M20. Except.... 3/4"-UNC is 10 threads per inch. 25.4 mm for 10 threads. You need a thread gauge to tell for sure. Regardless, 3/4" is 19 mm and that is not 19 mm. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 2, 2020 Author Share Posted May 2, 2020 the threads measure 25 mm for 10 turns , so it must be M20 ... but if the 3/4" UNC is 19 mm , then it would be possible to retread it to 3/4 .... that would give me a tight fit without the need to look for replacement radius arms . Are 3/4" dies affordable , or are they just as expensive as buying new radius arms , sandblast en paint en refit the bushes ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 2, 2020 Share Posted May 2, 2020 Does the nut tighten up on once you get down the thread a bit? If so then I wouldn't worry. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 2, 2020 Author Share Posted May 2, 2020 it is a selflocking nut , i can put it on till the plastic locking ring , and there is still a bit off play in it , don't know how far the threads project thru the nut when installed , it may get beter once the nut is on the correct spot Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 2, 2020 Share Posted May 2, 2020 It will, just look at the picture above..... Quote Link to comment Share on other sites More sharing options...
