Lockdown Repair work
Hope you are all doing ok and keeping safe in these weird times!ย
So as Iโ€™m self employed Iโ€™m currently doing hee haw work and still waiting on a help from the Gov ๐Ÿ™„ย
Anyhoo, I thought I might as well try my hand at repairing the 1987 110. The worst bits are the dreaded footwells and some bulkhead bits too.ย
i know others could have done a better job but Iโ€™m kinda chuffed how the offside went. Iโ€™m currently onto the near side. Few pics for you to get your fix ๐Ÿ˜Žย
That looks tidy. Its a ****ty job to do but good to have it done!
I have a new bulkhead for mine because I cant bring myself to do the repairs you have done! Now I cant motivate myself to do the bulkhead swap because I may as well do a chassis at the same time. Then I think I know what will actually happen and the 110 will get stripped to do a panel by panel re-spray and rebuild!
Aye itโ€™s a job alright Reb78 !! Iโ€™m actually enjoying it. Learning lots and now not so scared of things like this than I used to be ๐Ÿ˜ฑย
if your chassis is in good nick maybe get on with the Bulkhead swap? But Iโ€™d say make a start and the rest will follow ๐Ÿ˜Š๐Ÿ‘
Looks good - nice job !
We have 2 chassis waiting here for the travel bans to be lifted so we can get them galvanized and start a rebuild...
  • Like 1
Also been blessed with the weather to get on with it. Cuppa in hand,ย breaky about to go on and then get stuck in. ๐Ÿ˜Ž๐Ÿ‘
Thatโ€™s a fine job you have done there. Scary to see the corrosion behind those panels but l guess the vehicle is 33 years old.
How many cars last 33 years with daily use and are still running?
Itโ€™s going to be good for another thirty years when you have finished.
  • Like 1
Thanksย lightning, wasnโ€™t able to see just how bad it was until I got the wing off. Offside wing I took off with the galvi inner wing still attached, but the nearside I separated them which was easier. I hope it does last a while after all this ๐Ÿ˜Š๐Ÿ‘
Sitting on the deck in 22 ish degree sunshine enjoying a cold one after what was a longgg day on the rebuild. (I know not as big as some are doing)ย
Itโ€™s almost there and I reckon tomorrow itโ€™ll be test drive time. Fingers crossed ๐Ÿ˜Žโ˜€๏ธ๐Ÿบ๐Ÿ‘
hope youโ€™re all doing ok
  • Like 2
