Cornish Rattler Posted May 2, 2020 Share Posted May 2, 2020 Hi guys Can anyone tell if a Disco 200tdi FIP is the same as a Defender 200tdi FIP please and what the differences are if any Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted May 2, 2020 Share Posted May 2, 2020 As far as I know the Bosch VE pump is standard fitment on both 200/300 Tdi's and I *think* the only difference might be in the setup of the fuel pin inside (under the diaphragm) which can have varying shapes to give different fuel delivery curves for each engine. An expert may come along shortly and correct me! Quote Link to comment Share on other sites More sharing options...
Eightpot Posted May 2, 2020 Share Posted May 2, 2020 Not aware of any differences on the 200 pumps. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 2, 2020 Share Posted May 2, 2020 There are minor differences between Disco and Defender 200Tdi pumps I believe - the engines had different tunes due to the location of the turbo. I’m told by Diesel Bob that the differences are so slight that they will run fine on either setup, though when I had my spare (Disco) pump rebuilt I had it put in Defender spec anyway. A 200Tdi pump is different to a 300Tdi pump by a greater margin, the injectors have different opening pressures for example. Nevertheless apparently it will run on either setup as well, though not as well as it could. Later 300Tdi autos had the EDC pump which has more differences. 1 Quote Link to comment Share on other sites More sharing options...
Cornish Rattler Posted May 3, 2020 Author Share Posted May 3, 2020 Cheer's guys it's just I thought I had read somewhere that the Def 200 FIP's were more lower geared than Disco 200 FIP's. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 4, 2020 Share Posted May 4, 2020 As far as i know the governor limit is different between disco 200 and defender 200, 4100rpm vs 3900rpm 1 Quote Link to comment Share on other sites More sharing options...
JacobCl86 Posted May 4, 2020 Share Posted May 4, 2020 9 hours ago, Gremlin said: As far as i know the governor limit is different between disco 200 and defender 200, 4100rpm vs 3900rpm you are absolutely right! Quote Link to comment Share on other sites More sharing options...
