Green200tdi Posted May 6, 2020 Share Posted May 6, 2020 Fitted rx8 seats a while back has anyone got wiring diagram? I can get the electric seat to do everything but go back and forward, thank you Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted May 6, 2020 Share Posted May 6, 2020 Check here: As your fitting photos could be handy and mad_pete may have worked out the wiring! Steve Quote Link to comment Share on other sites More sharing options...
mad_pete Posted May 6, 2020 Share Posted May 6, 2020 I can find the wiring diagram. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted May 6, 2020 Share Posted May 6, 2020 Electrics on the seats: Yellow Plug - SRS, bin this Seat Motion - Thick Grey +12V Thick Purple Ground Lumber - Yellow Red Trace +12V White Yellow Trace Ground Seat Heater - Blue +12V Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 6, 2020 Author Share Posted May 6, 2020 👍 Quote Link to comment Share on other sites More sharing options...
Green200tdi Posted May 6, 2020 Author Share Posted May 6, 2020 Right all working apart from back and forward if I remove the plug both pins are live when I push middle switch one way light goes out swap pins push switch oppersit direction light goes off Quote Link to comment Share on other sites More sharing options...
Dr0v3r Posted February 14, 2021 Share Posted February 14, 2021 Fitted RX8 seats a while back. Wired the driver one up fine, but never got around to wiring up the seat heaters. With all this cold weather it has inspired me to get on with wiring up the seat heaters. I bought some relays to fit under the passenger seat, but I am unsure of what size cable to use for the heater power supply, and what size fuse I should fit. I could work it out with some Maffs, but that would make my head hurt. Has anyone already done this? What size cable did you use, and what size fuse? Quote Link to comment Share on other sites More sharing options...
