TIPTOP123 Posted May 9, 2020 Share Posted May 9, 2020 Hi folks just new to forum and to discoverys, have bought one and dicovered thers a leak from the Pas seems to be center front of the vehicle sort of just back a from the radiator anyone no off hand what i can expect this to be thanks Quote Link to comment Share on other sites More sharing options...
bear Posted May 9, 2020 Share Posted May 9, 2020 It'll be the power steering pipes that run under the rad rusted. Quote Link to comment Share on other sites More sharing options...
TIPTOP123 Posted May 9, 2020 Author Share Posted May 9, 2020 1 hour ago, bear said: It'll be the power steering pipes that run under the rad rusted. Wheres best to get new ones, handy enough to change? Quote Link to comment Share on other sites More sharing options...
bear Posted May 10, 2020 Share Posted May 10, 2020 Here's a link to the part number for you to Google and a search on line should give you the info for replacing them. Not done it mysekf but looks like the rads got to come out. http://new.lrcat.com/#!/1232/39655/39656/3043/39686 Griff Quote Link to comment Share on other sites More sharing options...
bear Posted May 10, 2020 Share Posted May 10, 2020 And here#s a write up http://www.thed2boysclub.co.uk/viewtopic.php?f=15&t=3910 Quote Link to comment Share on other sites More sharing options...
Sabre Posted May 12, 2020 Share Posted May 12, 2020 On 5/9/2020 at 8:57 PM, TIPTOP123 said: Hi folks just new to forum and to discoverys, have bought one and dicovered thers a leak from the Pas seems to be center front of the vehicle sort of just back a from the radiator anyone no off hand what i can expect this to be thanks If it's a Tdi, the metal pipes can chaff through in the brackets that hold the pipes in place. I fitted two pieces of rubber pipe around the metal pipes (1 inch each) and then fastened the pipes to the bracket with a few zip-ties Quote Link to comment Share on other sites More sharing options...
ballcock Posted May 13, 2020 Share Posted May 13, 2020 If it's the low pressure pipe (return from pump) you can get away with a rubber pipe until a replacement is found. Quote Link to comment Share on other sites More sharing options...
