Wabco power brakes - wiring diagram?
LiftedDisco
 Share
Doe anyone have a wiring diagram to go with the Wabco power brake system, as per ‘92 Range Rover Classic?
I’ve got the loom that runs the power brakes, but there is a connector that links into the main loom and I’d like to understand what works what... where the connections end up etc.
Can anyone help?
Many thanks
Thank you - much appreciated!
I’ve now found the pages - the image you’ve shown is the ECU connection and I’m after the link into the main loom... it’s only about 6 wires and I’m likely to unknit the loom to track and trace the connections.
 Share
