landy_andy Posted May 11, 2020 Share Posted May 11, 2020 Hi, Can anyone confirm that the later lower steering column, part #QME500031 will replace the early type. Looking to make some space for custom inner wings on my D100 project with challenge style wings. Thanks ! Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted May 11, 2020 Share Posted May 11, 2020 Yes straight swap Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 11, 2020 Share Posted May 11, 2020 One thing to bear in mind Andy, the upper joint on the later ones aren't replaceable, half of the upper UJ is part of the shaft. Where do you need to make room? In my build thread I documented how swapping the UJs top and bottom shifted the column over the desired amount for me. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 12, 2020 Author Share Posted May 12, 2020 Thanks guys, will have a play with the old one. Am working to make them out of flat sheet and I can get waterjet cut, so was working off the original lower mounts about a inch off the outside of the chassis rails. Quote Link to comment Share on other sites More sharing options...
missingsid Posted May 12, 2020 Share Posted May 12, 2020 As I like pics and wanted to understand this post better as I dont have a Defender, here is the parts drawing from Advanced Factors. Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 16, 2020 Author Share Posted May 16, 2020 For ‘missingsid’, here are a couple of pics under my drivers side wing. I currently have the old type of lower steering shaft RTC4738 but the large collapse section is getting in the way of making some sheet inner wings. Could someone measure the diameter of the black flex disc in the later QME500031, can get an idea then of how much space I have to work with. Thanks Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 17, 2020 Share Posted May 17, 2020 75mm Andy Mo Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 17, 2020 Author Share Posted May 17, 2020 5 hours ago, Mo Murphy said: 75mm Andy Mo Thanks Mo, spent a couple of hours yesterday on it and think I’ve come up with a good compromise that’ll work with the later type, will check it out with that dimension. BTW, the end of the collapse casting looks to be about 150mm from the UJ centre pivot and about same diameter? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 17, 2020 Share Posted May 17, 2020 I've split it Andy to show that there's about 30mm of length adjustment on the bottom UJ. HTH Mo Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 17, 2020 Share Posted May 17, 2020 Quote Link to comment Share on other sites More sharing options...
landy_andy Posted May 17, 2020 Author Share Posted May 17, 2020 Thanks Mo, that should work... drew up these lower inner wing panels, they'll attached to the original front tab & will add a second tab off the inside bolt on the spring tower that holds the bump stop mounts in. Can then work to draw the rest up as I'll have a solid datum. I wanted them to be easily removable with the wings in place for cleaning & maintenance, this should work well. 1 Quote Link to comment Share on other sites More sharing options...
