andy _1 Posted May 12, 2020 Share Posted May 12, 2020 Right yesterday I replaced a leaking leak back pipe all good 2 min job finished . I thought I heard a sucking type noise when I removed the pipe , but dismissed it "hearing things" went back to the car 2hours later went to start it it fired cut out tried again same again . Scratching my head ran out of diesel gauge showing half tank . Fourth attempt started running on 1 or 2 cylinder then 3/4. Right its drew air but how I cant figure it out how . I have removed leak back pipes for many cars and never had this. Can someone school me how on the 200 tdi the injectors drew air by removing the leak off pipe I thought that's on the return side confused. Thanks andy Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 12, 2020 Share Posted May 12, 2020 It allows the fuel to drain out of the injection pump. Quote Link to comment Share on other sites More sharing options...
andy _1 Posted May 12, 2020 Author Share Posted May 12, 2020 (edited) Ah right thanks it let's air into the pump it was the last injector before the return. Thanks that would have took me hours brainstorming 👍 Edited May 12, 2020 by andy _1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted May 12, 2020 Share Posted May 12, 2020 I find the replacement part for this to be poor. That's the soft rubber, pipe. So I used Mercedes Benz 603 leak off pipes. superb quality Quote Link to comment Share on other sites More sharing options...
