jokeruk Posted May 12, 2020 Share Posted May 12, 2020 Hi all , ‘I’ve had a search around and can’t find a clear answer to this. Can I fit a later Puma heated windscreen to my ‘86 110 ? I’m building up the enthusiasm to replace the bulkhead and am starting to collect all the parts and my existing screen has many scratches so putting in a heated one seems a good call (even if I don’t wire it in immediately) thanks in advance Steve 1986 110 Quote Link to comment Share on other sites More sharing options...
Eightpot Posted May 12, 2020 Share Posted May 12, 2020 I've fitted a late heated screen, easy enough - ideally pick up a heated screen timer relay from Range Rover classic, a momentary switch and suitable cable and it's an easy job. If you do a forum search there is good information. Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2020 Share Posted May 12, 2020 It's the same shape & size as every other 90/110 front screen, there are 2 or 3 terminal types, the 2 terminal are 12v +ve on one side & earth on other side the 3 terminal [mine] is earth on centre terminal & 12v +ve to the 2 outer terminals. Quote Link to comment Share on other sites More sharing options...
L19MUD Posted May 12, 2020 Share Posted May 12, 2020 I bought mine from Masai 4x4 with a new seal for £150 , fitted it the other day with no problems Quote Link to comment Share on other sites More sharing options...
jokeruk Posted May 12, 2020 Author Share Posted May 12, 2020 Thanks for the replies- very helpful. ..so that’s something else on the shopping list Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2020 Share Posted May 12, 2020 these guys do heated screens too https://www.heatedwindscreen.com/acatalog/land-rover-heated-windscreens.html#a7004ACLR Quote Link to comment Share on other sites More sharing options...
