Stellaghost Posted May 14, 2020 Share Posted May 14, 2020 My cebora 180 autostar has decided not to play the contactor pictured below does not always hold in which means no wire speed I'm assuming issue is with contactor probably dirty / burnt contacts only bother is these are now obsolete welder is nearly 30 yrs old and this is the first issue I've had with it doesn't owe me anything contactor I'm after is a fantini cosmi hr0910 not having a lot of joy on the net or do I bite the bullet and get a new mig from r tech any advice welcome regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted May 14, 2020 Share Posted May 14, 2020 Is it just to switch the wire feed and gas solenoid ? Do you know what voltage it operates on ? There must be something Industrial that will replace that , contactors are used in so many applications . Might be worth asking on the MIG welding forum too . cheers Steve b 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 14, 2020 Author Share Posted May 14, 2020 Yes just for wire feed and gas has 9a 600vac written on it regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted May 14, 2020 Share Posted May 14, 2020 Have a look on RSComponents www.rs-online.com for contactors , set the filters to what you need . 890_4238 looks promising? cheers Steve b 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 14, 2020 Share Posted May 14, 2020 Local electrical factors should be able to match it - that's what I did when the one in my lathe gave up. Cost me all of about £30. Think the one in my welder has given up now too - mind you, date code says 1974 so I've had some mileage out of it! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 14, 2020 Author Share Posted May 14, 2020 One of the sparks from work is going to look at it tomorrow my problem is that it may be a fault in circuit board that's causing the contactor to drop out and if it's anything to do with board I'm just gonna buy a new welder regards Stephen Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 14, 2020 Share Posted May 14, 2020 2 hours ago, FridgeFreezer said: Local electrical factors should be able to match it - that's what I did when the one in my lathe gave up. Cost me all of about £30. Think the one in my welder has given up now too - mind you, date code says 1974 so I've had some mileage out of it! Talking of mileage... if the welder is that old, I wonder how many miles of wire have been through it in that time Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 15, 2020 Share Posted May 15, 2020 16 hours ago, Stellaghost said: One of the sparks from work is going to look at it tomorrow my problem is that it may be a fault in circuit board that's causing the contactor to drop out and if it's anything to do with board I'm just gonna buy a new welder regards Stephen If it's anything like mine the circuit board has about 3 basic components on it - don't junk a solid welder if there's prospect of an easy repair, the older ones with proper transformers etc. are way more robust than the modern inverter stuff. If I was local I'd offer to nip round with the soldering iron and take a look! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 15, 2020 Author Share Posted May 15, 2020 That's a nice offer thankyou you may get it in the post yet to check lol regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 16, 2020 Author Share Posted May 16, 2020 It's alive !! Working great so far this morning when looking at stuff inside I noticed a plastic electrical gizmo was not connected to rail properly when I tried to re- fix it found a wire had snapped from soldered connection probably giving me an intermittent connection ( left hand orange thingy showing loose with soldered connections behind it ) anyway re- soldered and seems to be working fine at the moment fingers crossed thanks for assistance given guys regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 17, 2020 Share Posted May 17, 2020 Sweet, glad it's back live and kicking! 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted May 17, 2020 Author Share Posted May 17, 2020 Cheers John took on board what you said about the older transformer welders definitely worth repairing and keeping as long as I can as said previously this is the first problem I've had in nearly 30yrs of use and believe me it's used constantly been the best £500 I've ever spent and even then it was an ex display model regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 23, 2020 Author Share Posted November 23, 2020 (edited) So my cebora ceased to work, contactor stuck in and wire live all the time, freed contactor off and welder not working at all with regard to wire going live to weld feed still working got a new contactor from city electrical factors and a separate 24v coil put it together and now working better than ever, how's that your asking, since I moved into present house welder would not work on highest setting and only for a limited time on setting no5 ,I put it down to modern sensitive rcd's, now it works great on all settings, all the signs were there in hindsight I just didn't see them, my original contactor would be around 25/28 years old and contacts would have been burnt after that much use so all good now, hopefully some of you might find this helpful in the future regards Stephen Edited November 23, 2020 by Stellaghost 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 23, 2020 Share Posted November 23, 2020 Always nice to hear of something being fixed and not just chucked like so many people do these days. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 23, 2020 Author Share Posted November 23, 2020 5 minutes ago, landroversforever said: Always nice to hear of something being fixed and not just chucked like so many people do these days. I definitely do not subscribe to the disposable crowd that is popular these days regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted November 24, 2020 Share Posted November 24, 2020 I have just serviced my 1987 Cebora spot welder, that thing is built to last forever, the contactor is designed to be serviced with quick release contacts that allow them to be cleaned off if burnt and refitted in seconds. Trouble is that it does trip modern RCDs instantly, they are too sensitive for welders. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 24, 2020 Share Posted November 24, 2020 16 hours ago, oneandtwo said: I have just serviced my 1987 Cebora spot welder, that thing is built to last forever, the contactor is designed to be serviced with quick release contacts that allow them to be cleaned off if burnt and refitted in seconds. Trouble is that it does trip modern RCDs instantly, they are too sensitive for welders. Need a different classification of RCD then, one designed to handle the in-rush current. Quote Link to comment Share on other sites More sharing options...
SteveG Posted November 24, 2020 Share Posted November 24, 2020 5 hours ago, landroversforever said: Need a different classification of RCD then, one designed to handle the in-rush current. Or put a suitable diode in series. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 24, 2020 Share Posted November 24, 2020 53 minutes ago, SteveG said: Or put a suitable diode in series. That's a bit beyond my magical smoke tube knowledge Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 24, 2020 Share Posted November 24, 2020 Parallel? Quote Link to comment Share on other sites More sharing options...
Pav Posted March 3, 2022 Share Posted March 3, 2022 Hello, could you please help me with contactor hr0910 what kind of substitute/replacement I can get. Thanks Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 4, 2022 Author Share Posted March 4, 2022 12 hours ago, Pav said: Hello, could you please help me with contactor hr0910 what kind of substitute/replacement I can get. Thanks I just went to City Electrical Factors with my old one and they sorted me out regards Stephen Quote Link to comment Share on other sites More sharing options...
Pav Posted March 5, 2022 Share Posted March 5, 2022 Hello Stephen. Could you please take picture and let me know what contactor identification code is on yours from CEF. Thanks Kind regards Pav Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 5, 2022 Author Share Posted March 5, 2022 10 minutes ago, Pav said: Hello Stephen. Could you please take picture and let me know what contactor identification code is on yours from CEF. Thanks Kind regards Pav will look on monday, work commitments this weekend regards Stephen Quote Link to comment Share on other sites More sharing options...
Pav Posted March 5, 2022 Share Posted March 5, 2022 1 hour ago, Stellaghost said: will look on monday, work commitments this weekend regards Stephen Thanks. Don't work to hard. Have a good weekend. Regards Pav Quote Link to comment Share on other sites More sharing options...
